Re: [petsc-dev] PETSc release soon, request for input on needed fixes or enhancements
Executing: cd /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/arch-linux2-c-debug/externalpackages/git.hypre/src && ./configure --prefix=/opt/petsc-master_debug MAKE=/bin/gmake --libdir=/opt/petsc-master_debug/lib CC="/opt/openmpi-1.10.2/bin/mpicc" CFLAGS="-fPIC -g3" CXX="/opt/openmpi-1.10.2/bin/mpicxx" CXXFLAGS="-g -fPIC" F90="/opt/openmpi-1.10.2/bin/mpif90" F90FLAGS="-fPIC -ffree-line-length-0 -g" F77="/opt/openmpi-1.10.2/bin/mpif90" FFLAGS="-fPIC -ffree-line-length-0 -g" FC="/opt/openmpi-1.10.2/bin/mpif90" FCFLAGS="-fPIC -ffree-line-length-0 -g" --with-MPI-include="/opt/openmpi-1.10.2/include" --with-MPI-lib-dirs="" --with-MPI-libs="" --with-blas-lib="-Wl,-rpath,/opt/intel/composerxe/mkl/lib/intel64 -L/opt/intel/composerxe/mkl/lib/intel64 -lmkl_intel_lp64 -lmkl_core -lmkl_intel_thread -liomp5 -ldl -lpthread -lm -Wl,-rpath,/opt/openmpi-1.10.2/lib -L/opt/openmpi-1.10.2/lib -Wl,-rpath,/usr/lib/gcc/x86_64-redhat-linux/4.8.5 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5 -Wl,-rpath,/opt/intel/composer_xe_2015.2.164/compiler/lib/intel64 -L/opt/intel/composer_xe_2015.2.164/compiler/lib/intel64 -Wl,-rpath,/opt/intel/composer_xe_2015.2.164/ipp/lib/intel64 -L/opt/intel/composer_xe_2015.2.164/ipp/lib/intel64 -Wl,-rpath,/opt/intel/composer_xe_2015.2.164/mkl/lib/intel64 -L/opt/intel/composer_xe_2015.2.164/mkl/lib/intel64 -Wl,-rpath,/opt/intel/composer_xe_2015.2.164/tbb/lib/intel64/gcc4.4 -L/opt/intel/composer_xe_2015.2.164/tbb/lib/intel64/gcc4.4 -lmpi_usempi -lmpi_mpifh -lgfortran -lm -Wl,-rpath,/opt/openmpi-1.10.2/lib -Wl,-rpath,/usr/lib/gcc/x86_64-redhat-linux/4.8.5 -Wl,-rpath,/opt/intel/composer_xe_2015.2.164/compiler/lib/intel64 -Wl,-rpath,/opt/intel/composer_xe_2015.2.164/ipp/lib/intel64 -Wl,-rpath,/opt/intel/composer_xe_2015.2.164/mkl/lib/intel64 -Wl,-rpath,/opt/intel/composer_xe_2015.2.164/tbb/lib/intel64/gcc4.4 -lgfortran -lm -lquadmath -lm" --with-lapack-lib=" " --with-blas=no --with-lapack=no --with-fmangle-blas=one-underscore --with-fmangle-lapack=one-underscore --without-mli --without-fei --without-superlu AR="/bin/ar cr" checking for dgemm_ in -lm... no checking for dgemm_ in -lquadmath... no checking for dgemm_ in -lm... (cached) no checking for dgemm_ in -lgfortran... no checking for dgemm_ in -linux/4.8.5... no checking for dgemm_ in -lm... (cached) no checking for dgemm_ in -lgfortran... (cached) no checking for dgemm_ in -lmpi_mpifh... no checking for dgemm_ in -lmpi_usempi... no checking for dgemm_ in -linux/4.8.5... (cached) no checking for dgemm_ in -lm... (cached) no checking for dgemm_ in -lpthread... no checking for dgemm_ in -ldl... no checking for dgemm_ in -liomp5... no checking for dgemm_ in -lmkl_intel_thread... no checking for dgemm_ in -lmkl_core... no checking for dgemm_ in -lmkl_intel_lp64... noconfigure: error: **************** Non-linkable blas library error: *************************** User set BLAS library path using either --with-blas-lib=<lib>, or --with-blas-libs=<blas_lib_base_name> and --with-blas_dirs=<path-to-blas-lib>, but -L/opt/intel/composer_xe_2015.2.164/tbb/lib/intel64/gcc4.4 -L/opt/intel/composer_xe_2015.2.164/mkl/lib/intel64 -L/opt/intel/composer_xe_2015.2.164/ipp/lib/intel64 -L/opt/intel/composer_xe_2015.2.164/compiler/lib/intel64 -L/usr/lib/gcc/x86_64-redhat-linux/4.8.5 -L/opt/openmpi-1.10.2/lib -L/opt/intel/composerxe/mkl/lib/intel64 -lm -lquadmath -lm -lgfortran -Wl,-rpath,/opt/intel/composer_xe_2015.2.164/tbb/lib/intel64/gcc4.4 -Wl,-rpath,/opt/intel/composer_xe_2015.2.164/mkl/lib/intel64 -Wl,-rpath,/opt/intel/composer_xe_2015.2.164/ipp/lib/intel64 -Wl,-rpath,/opt/intel/composer_xe_2015.2.164/compiler/lib/intel64 -Wl,-rpath,/usr/lib/gcc/x86_64-redhat-linux/4.8.5 -Wl,-rpath,/opt/openmpi-1.10.2/lib -lm -lgfortran -lmpi_mpifh -lmpi_usempi -Wl,-rpath,/opt/intel/composer_xe_2015.2.164/tbb/lib/intel64/gcc4.4 -Wl,-rpath,/opt/intel/composer_xe_2015.2.164/mkl/lib/intel64 -Wl,-rpath,/opt/intel/composer_xe_2015.2.164/ipp/lib/intel64 -Wl,-rpath,/opt/intel/composer_xe_2015.2.164/compiler/lib/intel64 -Wl,-rpath,/usr/lib/gcc/x86_64-redhat-linux/4.8.5 -Wl,-rpath,/opt/openmpi-1.10.2/lib -lm -lpthread -ldl -liomp5 -lmkl_intel_thread -lmkl_core -lmkl_intel_lp64 -Wl,-rpath,/opt/intel/composerxe/mkl/lib/intel64 provided cannot be used. See "configure --help" for usage details. ***************************************************************************************** ******************************************************************************* Hm - instead of using all the libs from --with-blas-libs in a single link command - hypre is checking one '-llibrary' form this list at a time? [including -linux/4.8.5 which is from a -L option] '-lm -lpthread -ldl -liomp5 -lmkl_intel_thread -lmkl_core -lmkl_intel_lp64' ? Is hypre configure reversing the arguments it got? Its changed from --with-blas-lib='... -lmkl_intel_lp64 -lmkl_core -lmkl_intel_thread -liomp5 -ldl -lpthread -lm ...' I can reproduce this issue locally with: ./configure --download-hypre PETSC_ARCH=arch-hypre --with-blas-lapack-dir=/soft/com/packages/intel/15/update3/mkl --with-sowing=0 Satish On Sun, 28 Feb 2016, Eric Chamberland wrote:
Hi Barry,
the configuration of hypre looks broken since last night...?
Here is the log issued from our automatic compilation of petsc-master.tar.gz at 2016-02-28 02h00:
http://www.giref.ulaval.ca/~cmpgiref/petsc-master-debug/configure_20160228_0...
Everything was fine until last night...
Eric
Le 2016-02-27 15:36, Barry Smith a écrit :
PETSc Users,
We are planning the PETSc release 3.7 shortly. If you know of any bugs that need to be fixed or enhancements added before the release please let us know.
You can think of the master branch of the PETSc repository obtainable with
git clone https://bitbucket.org/petsc/petsc petsc
as a release candidate for 3.7. Changes for the release are listed at http://www.mcs.anl.gov/petsc/documentation/changes/dev.html
Thanks
Barry
participants (1)
Satish Balay
