Re: [petsc-dev] programming model for PETSc
On Thu, Nov 24, 2011 at 16:41, Matthew Knepley <[email protected]> wrote:
Let's start with the "lowest" level, or at least the smallest. I think the only sane way to program for portable performance here is using CUDA-type vectorization. This SIMT style is explained well here http://www.yosefk.com/blog/simd-simt-smt-parallelism-in-nvidia-gpus.html I think this is much easier and more portable than the intrinsics for Intel, and more performant and less error prone than threads. I think you can show that it will accomplish anything we want to do. OpenCL seems to have capitulated on this point. Do we agree here?
Moving from the other thread, I asked how far we could get with an API for high-level data movement combined with CUDA/OpenCL kernels. Matt wrote *I think it will get you quite far, and the point for me will be* *how will the user describe a communication pattern, and how will we automate the generation of MPI* *from that specification. Sieve has an attempt to do this buried in it inspired by the "manifold" idea.* * * Now that CUDA supports function pointers and similar, we can write real code in it. Whenever OpenCL gets around to supporting them, we'll be able to write real code for multicore and see how it performs. To unify the distributed and manycore aspects, we need some sort of hierarchical abstraction for NUMA and a communicator-like object to maintain scope. After applying a local-distribution filter, we might be able to express this using coloring plus the parallel primitives that I have been suggesting in the other thread. I'll think more on this and see if I can put together a concrete API proposal.
participants (1)
Jed Brown
