Re: [petsc-dev] Partial build
2 May
2 May
'12
4:02 p.m.
Normally both should work. Looks like 'lib' is broken. Satish On Wed, 2 May 2012, John Fettig wrote:
To answer my own question, it looks like you have to use libfast, not lib.
John
On Wed, May 2, 2012 at 4:54 PM, John Fettig <[email protected]> wrote:
If I modify src/vec/vec/impls/seq/seqcusp/veccusp.cu and then (in that directory) type "make lib", shouldn't it rebuild the library? I have also tried "make ACTION=lib tree" from higher up, and it still doesn't rebuild. What's the secret? This works for .c files.
Thanks, John
5214
Age (days ago)
5214
Last active (days ago)
0 comments
1 participants
participants (1)
Satish Balay
