XXXDestroy() mistaken design in PETSc
15 Feb
15 Feb
'11
4:47 p.m.
In MPI one calls MPI_Comm_free(&comm) to allow the MPI implementation to set the pointer explicitly to 0 after the object is destroyed. In Petsc XXXDestroy() does not pass the pointer (because it seemed too unnatural to me in 1994) thus not allowing 0ing the pointer. Was this a bad design decision? Should it be revisited? Barry Two use cases 1) error detection when someone tries to reuse a freed object 2) when removing some objects from a data structure that will be used data one currently needs to do XXXXDestroy(mystruct->something);CHKERRQ(ierr); mystruct->something = 0; instead of the cleaner XXXDestroy(&mystruct->something);CHKERRQ(ierr);
5656
Age (days ago)
5656
Last active (days ago)
0 comments
1 participants
participants (1)
Barry Smith
