Re: [petsc-dev] pushing MASSIVE change to PETSc-dev
21 Apr
21 Apr
'11
10:25 a.m.
On Apr 21, 2011, at 10:18 AM, Jed Brown wrote:
One consequence of this change is that, in general, it should no longer be necessary to use the construct
if (x->y) {ierr = YDestroy(x->y);CHKERRQ(ierr)}
Instead, you should be able to always use
ierr = YDestroy(&x->y);CHKERRQ(ierr);
There are still some of the former around, but it should not be used in new code.
Correct, I removed all that I found but may have missed a few. Also you need not do VecDestroy(x->y); x->y = 0; since the destroy handles that automatically. I will make another sweep through the code to try to eliminate the unneeded checks. Barry
5591
Age (days ago)
5591
Last active (days ago)
0 comments
1 participants
participants (1)
Barry Smith
