Dear Professor, Attachment is the alltests.log file. Best, Gang ------------------ 原始邮件 ------------------ 发件人: "petsc-dev" <[email protected]>; 发送时间: 2021年4月6日(星期二) 中午12:38 收件人: "petsc-dev"<[email protected]>; 抄送: "Chen Gang"<[email protected]>;"cglwdm"<[email protected]>; 主题: Re: [petsc-dev] Petsc: Error code 1 Note: do not use '-j' with alltests. And run alltests on both machines [but *not* at the same time on machines] and send us logs from both the runs. Satish On Mon, 5 Apr 2021, Satish Balay wrote: > Try: > > make alltests TIMEOUT=600 > > And send us the complete log (alltests.log) > > Satish > > On Tue, 6 Apr 2021, Chen Gang wrote: > > > Dear sir, > > > > > > The result of make check is OK. And I do set the timeout to a larger value, which keeps me from getting timeout error. The thing is I have two machines. And I get the error code 1 in different tests on different machines.I don’t know what is error code1. What case this? How can I fix the failure tests. > > > > > > ------------------ Original ------------------ > > From: Satish Balay <[email protected]> > > Date: Tue,Apr 6,2021 0:18 PM > > To: Chen Gang <[email protected]> > > Cc: petsc-dev <[email protected]>, cglwdm <[email protected]> > > Subject: Re: [petsc-dev] Petsc: Error code 1 >
participants (1)
Chen Gang
