Re: [petsc-dev] Error when calling PETSc
Hi Satish, I run this program with petsc-master on Linux with Valgrind and idb. Here is how I am calling PETSc: call MatCreateBAIJ(MPI_COMM_WORLD,nblock/2,N_mat,N_mat, > PETSC_DECIDE,PETSC_DECIDE,PETSC_DEFAULT_INTEGER,PNNZD, > PETSC_DEFAULT_INTEGER,PNNZO,mat,ierr) call MatSetup(mat,ierr) call MatSetOption(mat, MAT_NEW_NONZERO_ALLOCATION_ERR, > PETSC_FALSE) Any idea of this error?, both idb and valgrind points to matrixf.c:890 Thanks, Here is idb output: matsetoption_ (mat=0x36e1e48, op=0x32c2a20, flg=0x32c296c, __ierr=0x32c296c) at /home/hector/dwnld_prog/petsc-master/src/mat/interface/ftn-auto/matrixf.c:890 890 *__ierr = MatSetOption( And this is the valgrind output: $ valgrind --track-origins=yes --leak-check=full ./prog -d 3comp.dat ==18555== Memcheck, a memory error detector ==18555== Copyright (C) 2002-2013, and GNU GPL'd, by Julian Seward et al. ==18555== Using Valgrind-3.10.1 and LibVEX; rerun with -h for copyright info ==18555== Command: ./prog -d 3comp.dat ==18555== ==18555== Warning: set address range perms: large range [0x36fc000, 0x2e2b7000) (defined) NUMPRC: 1 PSTD, TRSTD = 14.6960000000000 519.670000000000 in INFLUID TIME TIMESTEP ITERATION FLASH_RES VOLUME_RES MASS_RES WATER_RES going into SOLVERS [0]PETSC ERROR: ------------------------------------------------------------------------ [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger [0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind [0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors [0]PETSC ERROR: likely location of problem given in stack below [0]PETSC ERROR: --------------------- Stack Frames ------------------------------------ [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available, [0]PETSC ERROR: INSTEAD the line number of the start of the function [0]PETSC ERROR: is given. [0]PETSC ERROR: --------------------- Error Message -------------------------------------------------------------- [0]PETSC ERROR: Signal received [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting. [0]PETSC ERROR: Petsc Development GIT revision: v3.6-34-gc9ff9ea GIT Date: 2015-06-17 23:52:21 -0500 [0]PETSC ERROR: ./prog on a linux-intel named petros.cpge.utexas.edu by hector Mon Jun 22 19:25:59 2015 [0]PETSC ERROR: Configure options --prefix=/home/hector/installed/petsc3.6-intel --PETSC_ARCH=linux-intel --with-mpi-dir=/home/hector/installed/openmpi-intel/ --with-parmetis-dir=/home/hector/installed/parmetis/ --with-metis-dir=/home/hector/installed/parmetis/ --with-zoltan-dir=/home/hector/installed/zoltan/ --download-ptscotch --download-hypre --with-blas-lapack-dir=/share/apps/intel/composer_xe_2011_sp1.9.293/mkl/ --with-valgrind=1 --with-valgrind-dir=/home/hector/installed --with-shared-libraries=0 [0]PETSC ERROR: #1 User provided function() line 0 in unknown file -------------------------------------------------------------------------- MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD with errorcode 59. NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes. You may or may not see output from other processes, depending on exactly when Open MPI kills them. -------------------------------------------------------------------------- ==18555== ==18555== HEAP SUMMARY: ==18555== in use at exit: 52,616,185 bytes in 7,935 blocks ==18555== total heap usage: 121,248 allocs, 113,313 frees, 69,099,609 bytes allocated ==18555== ==18555== 240 bytes in 6 blocks are definitely lost in loss record 5,950 of 6,383 ==18555== at 0x2ECBEAF0: malloc (vg_replace_malloc.c:296) ==18555== by 0x324D4798E1: strdup (in /lib64/libc-2.5.so) ==18555== by 0x331E1A27: opal_show_help_vstring (in /home/hector/installed/openmpi-intel/lib/libopen-pal.so.6.2.1) ==18555== by 0x32F30F53: orte_show_help (in /home/hector/installed/openmpi-intel/lib/libopen-rte.so.7.0.5) ==18555== by 0x32A5F709: PMPI_Abort (in /home/hector/installed/openmpi-intel/lib/libmpi.so.1.6.1) ==18555== by 0x245A9F3: PetscSignalHandlerDefault (signal.c:161) ==18555== by 0x245A356: PetscSignalHandler_Private (signal.c:49) ==18555== by 0x324D4302EF: ??? (in /lib64/libc-2.5.so) ==18555== by 0x20A104E: matsetoption_ (matrixf.c:890) ==18555== by 0x1BE0576: jpetsc3d_ (xsolver.f:382) ==18555== by 0x1BDC9A3: xsolver_ (xsolver.f:104) ==18555== by 0x1AB1BB3: solvers_ (xsolve.f:60) ==18555== ==18555== 336 bytes in 1 blocks are possibly lost in loss record 6,043 of 6,383 ==18555== at 0x2ECC0867: calloc (vg_replace_malloc.c:623) ==18555== by 0x324D0100A2: _dl_allocate_tls (in /lib64/ld-2.5.so) ==18555== by 0x324E006EB8: pthread_create@@GLIBC_2.2.5 (in /lib64/libpthread-2.5.so) ==18555== by 0x331BABB5: opal_thread_start (in /home/hector/installed/openmpi-intel/lib/libopen-pal.so.6.2.1) ==18555== by 0x32F43A18: orte_ess_base_app_setup (in /home/hector/installed/openmpi-intel/lib/libopen-rte.so.7.0.5) ==18555== by 0x34C503DE: rte_init (in /home/hector/installed/openmpi-intel/lib/openmpi/mca_ess_singleton.so) ==18555== by 0x32F222F5: orte_init (in /home/hector/installed/openmpi-intel/lib/libopen-rte.so.7.0.5) ==18555== by 0x32A4D67E: ompi_mpi_init (in /home/hector/installed/openmpi-intel/lib/libmpi.so.1.6.1) ==18555== by 0x32A7052E: PMPI_Init (in /home/hector/installed/openmpi-intel/lib/libmpi.so.1.6.1) ==18555== by 0x3122CB27: PMPI_INIT (in /home/hector/installed/openmpi-intel/lib/libmpi_mpifh.so.2.5.0) ==18555== by 0x1C89281: setprcs_ (man.f:144) ==18555== by 0x1C4CB98: MAIN__ (main.f:114) ==18555== ==18555== 7,550 bytes in 111 blocks are definitely lost in loss record 6,243 of 6,383 ==18555== at 0x2ECC0A3D: realloc (vg_replace_malloc.c:692) ==18555== by 0x324D469725: vasprintf (in /lib64/libc-2.5.so) ==18555== by 0x324D44D727: asprintf (in /lib64/libc-2.5.so) ==18555== by 0x331E913D: dlopen_foreachfile (in /home/hector/installed/openmpi-intel/lib/libopen-pal.so.6.2.1) ==18555== by 0x331CCBC0: mca_base_component_find (in /home/hector/installed/openmpi-intel/lib/libopen-pal.so.6.2.1) ==18555== by 0x331D5EC0: mca_base_framework_components_register (in /home/hector/installed/openmpi-intel/lib/libopen-pal.so.6.2.1) ==18555== by 0x331D62DE: mca_base_framework_register (in /home/hector/installed/openmpi-intel/lib/libopen-pal.so.6.2.1) ==18555== by 0x331D6331: mca_base_framework_open (in /home/hector/installed/openmpi-intel/lib/libopen-pal.so.6.2.1) ==18555== by 0x331B71E8: opal_init (in /home/hector/installed/openmpi-intel/lib/libopen-pal.so.6.2.1) ==18555== by 0x32F221C4: orte_init (in /home/hector/installed/openmpi-intel/lib/libopen-rte.so.7.0.5) ==18555== by 0x32A4D67E: ompi_mpi_init (in /home/hector/installed/openmpi-intel/lib/libmpi.so.1.6.1) ==18555== by 0x32A7052E: PMPI_Init (in /home/hector/installed/openmpi-intel/lib/libmpi.so.1.6.1) ==18555== ==18555== LEAK SUMMARY: ==18555== definitely lost: 7,790 bytes in 117 blocks ==18555== indirectly lost: 0 bytes in 0 blocks ==18555== possibly lost: 336 bytes in 1 blocks ==18555== still reachable: 52,608,059 bytes in 7,817 blocks ==18555== suppressed: 0 bytes in 0 blocks ==18555== Reachable blocks (those to which a pointer was found) are not shown. ==18555== To see them, rerun with: --leak-check=full --show-leak-kinds=all ==18555== ==18555== For counts of detected and suppressed errors, rerun with: -v ==18555== ERROR SUMMARY: 3 errors from 3 contexts (suppressed: 4 from 4) Hector On Fri, Jun 19, 2015 at 2:29 PM, Satish Balay <[email protected]> wrote:
PETSc thinks there is an error in user code. Its best if you run it in a debugger and check whats going on. [on linux one can also use valgrind to track down problems]
There are many changes from petsc3.1 to petsc-3.6. Make sure you go throgh the changes files. On C - one can rely on the compiler prototype checks to catch most of the changes. But with fortran - you might have to rely on a debugger/valgrind to [and the changes docs] to find the changes.
http://www.mcs.anl.gov/petsc/documentation/changes/index.html
Satish
On Fri, 19 Jun 2015, Hector E Barrios Molano wrote:
Hi Satish,
I used MatSetOption, I'm ignoring the performance penalty for now.
Now I have this error:
[0]PETSC ERROR: ------------------------------------------------------------------------ [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger [0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind [0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors [0]PETSC ERROR: likely location of problem given in stack below [0]PETSC ERROR: --------------------- Stack Frames ------------------------------------ [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available, [0]PETSC ERROR: INSTEAD the line number of the start of the function [0]PETSC ERROR: is given. [0]PETSC ERROR: --------------------- Error Message -------------------------------------------------------------- [0]PETSC ERROR: Signal received [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting. [0]PETSC ERROR: Petsc Development GIT revision: v3.6-34-gc9ff9ea GIT Date: 2015-06-17 23:52:21 -0500 [0]PETSC ERROR: F:\prog_win\prog\Debug\prog.exe on a windows-intel named HECTOR-PC by hector Fri Jun 19 14:06:17 2015 [0]PETSC ERROR: Configure options --with-cc="win32fe cl" --with-fc="win32fe ifort" --prefix=/cygdrive/c/Installed/petsc/ --PETSC_ARCH=windows-intel --with-parmetis-include=/cygdrive/c/Installed/parmetis/include --with-parmetis-lib=/cygdrive/c/Installed/parmetis/lib/parmetis.lib --with-metis-include=/cygdrive/c/Installed/parmetis/include --with-metis-lib=/cygdrive/c/Installed/parmetis/lib/metis.lib --with-mpi-include="[/cygdrive/c/Installed/msmpi/Include,/cygdrive/c/Installed/msmpi/Include/x64]" --with-mpi-lib="[/cygdrive/c/Installed/msmpi/Lib/x64/msmpi.lib,/cygdrive/c/Installed/msmpi/Lib/x64/msmpifec.lib]" --with-blas-lapack-lib="[/cygdrive/c/Installed/mkl/lib/intel64/mkl_intel_lp64.lib,/cygdrive/c/Installed/mkl/lib/intel64/mkl_core.lib,/cygdrive/c/Installed/mkl/lib/intel64/mkl_sequential.lib]" --with-scalapack-include=/cygdrive/c/Installed/mkl/include --with-scalapack-lib="[/cygdrive/c/Installed/mkl/lib/intel64/mkl_scalapack_lp64.lib,/cygdrive/c/Installed/mkl/lib/intel64/mkl_blacs_msmpi_lp64.lib]" [0]PETSC ERROR: #1 User provided function() line 0 in unknown file
job aborted: [ranks] message
[0] application aborted aborting MPI_COMM_WORLD (comm=0x44000000), error 59, comm rank 0
On Fri, Jun 19, 2015 at 12:57 PM, Satish Balay <[email protected]> wrote:
As the message says:
[0]PETSC ERROR: New nonzero at (0,20) caused a malloc Use MatSetOption(A, MAT_NEW_NONZERO_ALLOCATION_ERR, PETSC_FALSE) to turn off this check
Note: mallocs make the code slow - so its up to you to do a proper preallocation of memory - or disable the check as the above message indicadtes [and ignore the performance penalty for now.].
Satish
Hi PETSc Experts,
I'm compiling a Windows program using petsc-dev, this program previously used petsc-3.1 the only change performed was:
MatCreateMPIBAIJ --> MatCreateBAIJ
As the PETSc documentation suggested.
I only changed the name of the function.
I got to a problem when the program is launched and PETSc is called by the program:
[0]PETSC ERROR: --------------------- Error Message -------------------------------------------------------------- [0]PETSC ERROR: Argument out of range [0]PETSC ERROR: New nonzero at (0,20) caused a malloc Use MatSetOption(A, MAT_NEW_NONZERO_ALLOCATION_ERR, PETSC_FALSE) to turn off this check [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting. [0]PETSC ERROR: Petsc Development GIT revision: v3.6-34-gc9ff9ea GIT Date: 2015-06-17 23:52:21 -0500 [0]PETSC ERROR: F:\prog_win\prog\Debug\prog.exe on a windows-intel named HECTOR-PC by hector Thu Jun 18 18:31:42 2015 [0]PETSC ERROR: Configure options --with-cc="win32fe cl" --with-fc="win32fe ifort" --prefix=/cygdrive/c/Installed/petsc/ --PETSC_ARCH=windows-intel --with-parmetis-include=/cygdrive/c/Installed/parmetis/include --with-parmetis-lib=/cygdrive/c/Installed/parmetis/lib/parmetis.lib --with-metis-include=/cygdrive/c/Installed/parmetis/include --with-metis-lib=/cygdrive/c/Installed/parmetis/lib/metis.lib --with-mpi-include="[/cygdrive/c/Installed/msmpi/Include,/cygdrive/c/Installed/msmpi/Include/x64]" --with-mpi-lib="[/cygdrive/c/Installed/msmpi/Lib/x64/msmpi.lib,/cygdrive/c/Installed/msmpi/Lib/x64/msmpifec.lib]" --with-blas-lapack-lib="[/cygdrive/c/Installed/mkl/lib/intel64/mkl_intel_lp64.lib,/cygdrive/c/Installed/mkl/lib/intel64/mkl_core.lib,/cygdrive/c/Installed/mkl/lib/intel64/mkl_sequential.lib]" --with-scalapack-include=/cygdrive/c/Installed/mkl/include --with-scalapack-lib="[/cygdrive/c/Installed/mkl/lib/intel64/mkl_scalapack_lp64.lib,/cygdrive/c/Installed/mkl/lib/intel64/mkl_blacs_msmpi_lp64.lib]" [0]PETSC ERROR: #1 MatSetValues_SeqBAIJ() line 2192 in C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\impls\baij\seq\baij.c [0]PETSC ERROR: #2 MatSetValues() line 1175 in C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\INTERF~1\matrix.c [0]PETSC ERROR: --------------------- Error Message -------------------------------------------------------------- [0]PETSC ERROR: Argument out of range [0]PETSC ERROR: New nonzero at (1,21) caused a malloc Use MatSetOption(A, MAT_NEW_NONZERO_ALLOCATION_ERR, PETSC_FALSE) to turn off this check [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting. [0]PETSC ERROR: Petsc Development GIT revision: v3.6-34-gc9ff9ea GIT Date: 2015-06-17 23:52:21 -0500 [0]PETSC ERROR: F:\prog_win\prog\Debug\prog.exe on a windows-intel named HECTOR-PC by hector Thu Jun 18 18:31:42 2015 [0]PETSC ERROR: Configure options --with-cc="win32fe cl" --with-fc="win32fe ifort" --prefix=/cygdrive/c/Installed/petsc/ --PETSC_ARCH=windows-intel --with-parmetis-include=/cygdrive/c/Installed/parmetis/include --with-parmetis-lib=/cygdrive/c/Installed/parmetis/lib/parmetis.lib --with-metis-include=/cygdrive/c/Installed/parmetis/include --with-metis-lib=/cygdrive/c/Installed/parmetis/lib/metis.lib --with-mpi-include="[/cygdrive/c/Installed/msmpi/Include,/cygdrive/c/Installed/msmpi/Include/x64]" --with-mpi-lib="[/cygdrive/c/Installed/msmpi/Lib/x64/msmpi.lib,/cygdrive/c/Installed/msmpi/Lib/x64/msmpifec.lib]" --with-blas-lapack-lib="[/cygdrive/c/Installed/mkl/lib/intel64/mkl_intel_lp64.lib,/cygdrive/c/Installed/mkl/lib/intel64/mkl_core.lib,/cygdrive/c/Installed/mkl/lib/intel64/mkl_sequential.lib]" --with-scalapack-include=/cygdrive/c/Installed/mkl/include --with-scalapack-lib="[/cygdrive/c/Installed/mkl/lib/intel64/mkl_scalapack_lp64.lib,/cygdrive/c/Installed/mkl/lib/intel64/mkl_blacs_msmpi_lp64.lib]" [0]PETSC ERROR: #3 MatSetValues_SeqBAIJ() line 2192 in C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\impls\baij\seq\baij.c [0]PETSC ERROR: #4 MatSetValues() line 1175 in C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\INTERF~1\matrix.c . . . [0]PETSC ERROR: #3599 MatSetValues_SeqBAIJ() line 2192 in C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\impls\baij\seq\baij.c [0]PETSC ERROR: #3600 MatSetValues() line 1175 in C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\INTERF~1\matrix.c [0]PETSC ERROR: ------------------------------------------------------------------------ [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger [0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind [0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors [0]PETSC ERROR: likely location of problem given in stack below [0]PETSC ERROR: --------------------- Stack Frames ------------------------------------ [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not available, [0]PETSC ERROR: INSTEAD the line number of the start of the function [0]PETSC ERROR: is given. [0]PETSC ERROR: [0] MatSetValues line 1142 C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\INTERF~1\matrix.c [0]PETSC ERROR: [0] MatSetValues_SeqBAIJ line 2148 C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\impls\baij\seq\baij.c [0]PETSC ERROR: [0] MatSetValues line 1142 C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\INTERF~1\matrix.c [0]PETSC ERROR: [0] MatSetValues_SeqBAIJ line 2148 C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\impls\baij\seq\baij.c [0]PETSC ERROR: [0] MatSetValues line 1142 C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\INTERF~1\matrix.c [0]PETSC ERROR: [0] MatSetValues_SeqBAIJ line 2148 C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\impls\baij\seq\baij.c [0]PETSC ERROR: [0] MatSetValues line 1142 C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\INTERF~1\matrix.c [0]PETSC ERROR: [0] MatSetValues_SeqBAIJ line 2148 C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\impls\baij\seq\baij.c [0]PETSC ERROR: [0] MatSetValues line 1142 C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\INTERF~1\matrix.c [0]PETSC ERROR: [0] MatSetValues_SeqBAIJ line 2148 C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\impls\baij\seq\baij.c [0]PETSC ERROR: [0] MatSetValues line 1142 C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\INTERF~1\matrix.c [0]PETSC ERROR: [0] MatSetValues_SeqBAIJ line 2148 C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\impls\baij\seq\baij.c [0]PETSC ERROR: [0] MatSetValues line 1142 C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\INTERF~1\matrix.c [0]PETSC ERROR: [0] MatSetValues_SeqBAIJ line 2148 C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\impls\baij\seq\baij.c [0]PETSC ERROR: [0] MatSetValues line 1142 C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\INTERF~1\matrix.c [0]PETSC ERROR: [0] MatSetValues_SeqBAIJ line 2148 C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\impls\baij\seq\baij.c [0]PETSC ERROR: [0] MatSetValues line 1142 C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\INTERF~1\matrix.c [0]PETSC ERROR: [0] MatSetValues_SeqBAIJ line 2148 C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\impls\baij\seq\baij.c [0]PETSC ERROR: [0] MatSetValues line 1142 C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\INTERF~1\matrix.c [0]PETSC ERROR: [0] MatSetValues_SeqBAIJ line 2148 C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\impls\baij\seq\baij.c [0]PETSC ERROR: [0] MatSetValues line 1142 C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\INTERF~1\matrix.c [0]PETSC ERROR: [0] MatSetValues_SeqBAIJ line 2148 C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\impls\baij\seq\baij.c [0]PETSC ERROR: [0] MatSetValues line 1142 C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\INTERF~1\matrix.c [0]PETSC ERROR: [0] MatSetValues_SeqBAIJ line 2148 C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\impls\baij\seq\baij.c [0]PETSC ERROR: [0] MatSetValues line 1142 C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\INTERF~1\matrix.c [0]PETSC ERROR: [0] MatSetValues_SeqBAIJ line 2148 C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\impls\baij\seq\baij.c [0]PETSC ERROR: [0] MatSetValues line 1142 C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\INTERF~1\matrix.c [0]PETSC ERROR: [0] MatSetValues_SeqBAIJ line 2148 C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\impls\baij\seq\baij.c [0]PETSC ERROR: [0] MatSetValues line 1142 C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\INTERF~1\matrix.c [0]PETSC ERROR: [0] MatSetValues_SeqBAIJ line 2148 C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\impls\baij\seq\baij.c [0]PETSC ERROR: [0] MatSetValues line 1142 C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\INTERF~1\matrix.c [0]PETSC ERROR: [0] MatSetValues_SeqBAIJ line 2148 C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\impls\baij\seq\baij.c [0]PETSC ERROR: [0] MatSetValues line 1142 C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\INTERF~1\matrix.c [0]PETSC ERROR: [0] MatSetValues_SeqBAIJ line 2148 C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\impls\baij\seq\baij.c [0]PETSC ERROR: [0] MatSetValues line 1142 C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\INTERF~1\matrix.c [0]PETSC ERROR: [0] MatSetValues_SeqBAIJ line 2148 C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\impls\baij\seq\baij.c [0]PETSC ERROR: [0] MatSetValues line 1142 C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\INTERF~1\matrix.c [0]PETSC ERROR: [0] MatSetValues_SeqBAIJ line 2148 C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\impls\baij\seq\baij.c [0]PETSC ERROR: [0] MatSetValues line 1142 C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\INTERF~1\matrix.c [0]PETSC ERROR: [0] MatSetValues_SeqBAIJ line 2148 C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\impls\baij\seq\baij.c [0]PETSC ERROR: [0] MatSetValues line 1142 C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\INTERF~1\matrix.c [0]PETSC ERROR: [0] MatSetValues_SeqBAIJ line 2148 C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\impls\baij\seq\baij.c [0]PETSC ERROR: [0] MatSetValues line 1142 C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\INTERF~1\matrix.c [0]PETSC ERROR: [0] MatSetValues_SeqBAIJ line 2148 C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\impls\baij\seq\baij.c [0]PETSC ERROR: [0] MatSetValues line 1142 C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\INTERF~1\matrix.c [0]PETSC ERROR: [0] MatSetValues_SeqBAIJ line 2148 C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\impls\baij\seq\baij.c [0]PETSC ERROR: [0] MatSetValues line 1142 C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\INTERF~1\matrix.c [0]PETSC ERROR: [0] MatSetValues_SeqBAIJ line 2148 C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\impls\baij\seq\baij.c [0]PETSC ERROR: [0] MatSetValues line 1142 C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\INTERF~1\matrix.c [0]PETSC ERROR: [0] MatSetValues_SeqBAIJ line 2148 C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\impls\baij\seq\baij.c [0]PETSC ERROR: [0] MatSetValues line 1142 C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\INTERF~1\matrix.c [0]PETSC ERROR: [0] MatSetValues_SeqBAIJ line 2148 C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\impls\baij\seq\baij.c [0]PETSC ERROR: [0] MatSetValues line 1142 C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\INTERF~1\matrix.c [0]PETSC ERROR: [0] MatSetValues_SeqBAIJ line 2148 C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\impls\baij\seq\baij.c [0]PETSC ERROR: [0] MatSetValues line 1142 C:\INSTAL~1\PETSC-~1\PETSC-~1\src\mat\INTERF~1\matrix.c [0]PETSC ERROR: --------------------- Error Message -------------------------------------------------------------- [0]PETSC ERROR: Signal received [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting. [0]PETSC ERROR: Petsc Development GIT revision: v3.6-34-gc9ff9ea GIT Date: 2015-06-17 23:52:21 -0500 [0]PETSC ERROR: F:\prog_win\prog\Debug\prog.exe on a windows-intel named HECTOR-PC by hector Fri Jun 19 12:43:06 2015 [0]PETSC ERROR: Configure options --with-cc="win32fe cl" --with-fc="win32fe ifort" --prefix=/cygdrive/c/Installed/petsc/ --PETSC_ARCH=windows-intel --with-parmetis-include=/cygdrive/c/Installed/parmetis/include --with-parmetis-lib=/cygdrive/c/Installed/parmetis/lib/parmetis.lib --with-metis-include=/cygdrive/c/Installed/parmetis/include --with-metis-lib=/cygdrive/c/Installed/parmetis/lib/metis.lib --with-mpi-include="[/cygdrive/c/Installed/msmpi/Include,/cygdrive/c/Installed/msmpi/Include/x64]" --with-mpi-lib="[/cygdrive/c/Installed/msmpi/Lib/x64/msmpi.lib,/cygdrive/c/Installed/msmpi/Lib/x64/msmpifec.lib]" --with-blas-lapack-lib="[/cygdrive/c/Installed/mkl/lib/intel64/mkl_intel_lp64.lib,/cygdrive/c/Installed/mkl/lib/intel64/mkl_core.lib,/cygdrive/c/Installed/mkl/lib/intel64/mkl_sequential.lib]" --with-scalapack-include=/cygdrive/c/Installed/mkl/include --with-scalapack-lib="[/cygdrive/c/Installed/mkl/lib/intel64/mkl_scalapack_lp64.lib,/cygdrive/c/Installed/mkl/lib/intel64/mkl_blacs_msmpi_lp64.lib]" [0]PETSC ERROR: #3601 User provided function() line 0 in unknown file
I'm compiling the program on Visual Studio, what could be the problem?
Thanks for your help,
Hector
participants (1)
