Re: [petsc-dev] MacOS firewall annoyance while running tests + solution
On Fri, Aug 28, 2020 at 11:44 PM Satish Balay <[email protected]> wrote:
Likely firewall is disabled.
I've recently rebuild a bunch of boxes - and don't remember explicity disabling firewall. [well I did something to enable ssh - maybe that was disabling firewall]
I see the firewall is disabled on all of them
You are right, as always. Thanks, Matt
balay@ypro ~ % defaults read /Library/Preferences/com.apple.alf globalstate 0 balay@ypro ~ %
Ref: https://raymii.org/s/snippets/OS_X_-_Turn_firewall_on_or_off_from_the_comman...
BTW: Perhaps the following setting will prevent popups? [but it might break stuff that need network?]
sudo defaults write /Library/Preferences/com.apple.alf globalstate -int 2
Satish
On Fri, 28 Aug 2020, Matthew Knepley wrote:
Which OS is this? It does not happen on my Catalina.
Matt
On Fri, Aug 28, 2020 at 10:52 PM Barry Smith <[email protected]> wrote:
On Aug 28, 2020, at 3:47 PM, Jed Brown <[email protected]> wrote:
"Hapla Vaclav" <[email protected]> writes:
On MacOS, maybe you also have lots of firewall popups appearing/disappearing when running tests like Do you want the application "ex29" to accept incoming network
connections?
Is there a way to express that the application does not need (should
not
accept) incoming connections?
Yes, this also seems to work:
sudo $$FW --block $$APP
instead of
sudo $$FW --unblock $$APP
The parallel program still runs correctly to conclusion without the popup.
So my conclusion is that at listen() or some later system call it always pops up the window (unless the user as already blocked or unblocked the executable) without regard to whether an outside (from the machine) connection to the process is attempted.
The routine has an undocumented option -a <listen or accept> when you run with
/usr/libexec/ApplicationFirewall/socketfilterfw -d -a accept
it prints ASKWHENACCEPT which seems to indicate it will delay the popup until an accept is called but I can't confirm this because the debugger never stops in accept on one process but the popup still comes up so this argument may be ignored.
If I were Junchao I would not do the popup until the code tried to accepted an EXTERNAL connection (the lazy evaluation) but I cannot get it to behave this way.
If I disconnect from the network I still get the popups.
The pop up is asynchronous also, when the popup is still up the program keeps run (even in parallel) and ends normally. Then the popup disappears.
Apple could make this friendly without hurting security but then Apple never cared about external developers for the Mac.
Normalizing sudo during build/testing seems really bad.
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
participants (1)
Matthew Knepley
