I told everyone in that thread how it should be fixed. The fix for this is to add PetscObjectSetName() to src/sys/f90-mod/petscsys.h90 with the * notation to allow any type. You will see in that file PetscObjectReference() etc. PetsFE is an INTEGER(8) in Fortran because no one has updated it yet to be a Fortran type. You will see in include/petsc/finclude/petscdm.h that only DM has be properly updated to be a Fortran type, a bunch of others are still treated as integers and need to be fixed eventually. #define DM type(tDM) #define DMAdaptor PetscFortranAddr #define PetscQuadrature PetscFortranAddr #define PetscDS PetscFortranAddr #define PetscFE PetscFortranAddr #define PetscSpace PetscFortranAddr #define PetscDualSpace PetscFortranAddr #define PetscFV PetscFortranAddr #define PetscLimiter PetscFortranAddr #define PetscPartitioner PetscFortranAddr #define DMField PetscFortranAddr We do not need to configure check this, we need to fix the PETSc source so it follows F90 (yes, F90 standards, Gnu is still catching up :-). Barry A separate issue is external packages do not follow Fortran standards so generate such errors as well, but that is not our business, we just always force turn off the Fortran error checking for external packages.
On Jul 13, 2020, at 12:34 PM, Matthew Knepley <[email protected]> wrote:
Why did Mark have the gcc 10 failure on our example. Was it something with did in it?
Matt
On Mon, Jul 13, 2020 at 12:43 PM Jed Brown <[email protected] <mailto:[email protected]>> wrote: You want this for PETSc or for external packages? We add it for a bunch of external packages. I've been building PETSc with gcc/gfortran-10 for months now.
Matthew Knepley <[email protected] <mailto:[email protected]>> writes:
Do we have gfortran from gcc 10 running anywhere? We need a check to enable
-fallow-argument-mismatch
from configure. Should be as simple as compiling Fortran which has PetscObjectSetName() in it.
Matt
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <https://www.cse.buffalo.edu/~knepley/> <http://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>>
participants (1)
Barry Smith
