Re: [petsc-dev] Are pipelines down?
Only folk in developer group have permissions to use the CI resources [to avoid drive by hacks and consumption of resources etc] And as a developer you have to create a 'new pipeline' - not use the auto-started pipeline [this auto-stated pipeline from a fork is from a user account that does not have access to CI resources - so these pipelines will stay stuck] I think its best for one of the developers to start the pipeline after verifying the code is ok to run. If any of the reviewers approve - then I can do this. Satish On Fri, 12 Mar 2021, Matthew Knepley wrote:
On Fri, Mar 12, 2021 at 9:26 AM Pierre Jolivet <[email protected]> wrote:
You are linking to the forks, i.e., not …/petsc/petsc/…, you’ll never see anything going on there, I think. I’ve started the pipelines by clicking “Run Pipeline” here https://gitlab.com/petsc/petsc/-/merge_requests/3616/pipelines and there https://gitlab.com/petsc/petsc/-/merge_requests/3707/pipelines
Thanks Pierre. There are things I obviously do not understand about Gitlab :)
Matt
Thanks, Pierre
On 12 Mar 2021, at 3:02 PM, Matthew Knepley <[email protected]> wrote:
On Fri, Mar 12, 2021 at 7:29 AM Matthew Knepley <[email protected]> wrote:
On Thu, Mar 11, 2021 at 11:24 PM Satish Balay <[email protected]> wrote:
For forks - a member of the developer group needs to start a new pipeline. (after basic checks on the changes)
The original pipeline just sat pending in the source check, so I cancelled it.
I created a new pipeline, but it is just sitting pending in the source check
https://gitlab.com/danfinn/petsc/-/pipelines/269297070
Why will this not run?
Same problem for Connor's branch: https://gitlab.com/connorjward/petsc/-/pipelines/269584870
Matt
Matt
Satish
On Thu, 11 Mar 2021, Jed Brown wrote:
Says the pipeline was canceled. The branch comes from a fork so it should need approval to run.
Matthew Knepley <[email protected]> writes:
Matt
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ < http://www.cse.buffalo.edu/~knepley/>
participants (1)
Satish Balay
