Re: [petsc-dev] Fwd: [petsc-maint #70675] update of the timestep in theta method
18 Apr
18 Apr
'11
2:19 p.m.
On Mon, Apr 18, 2011 at 21:17, Jeremy Riousset <[email protected]> wrote:
I was thinking to call it in the Monitor function.
You can also do that, but then the output of other monitors is dependent on whether it comes before or after your "monitor" changes the step size. Using TSSetPostStep is better in that regard because it is consistent.
5597
Age (days ago)
5597
Last active (days ago)
0 comments
1 participants
participants (1)
Jed Brown
