Re: [petsc-dev] Error: 'ooc_nb_file_type' at (1) is not a member of the 'cmumps_struc' structure
Configure Options: --configModules=PETSc.Configure --optionsModule=config.compilerOptions --prefix=/home/chaffra/Projects/FEniCS COPTFLAGS=-O2 --with-debugging=1 --with-shared-libraries=1 --with-clanguage=cxx --with-c-support=1 --with-pthreadclasses=1 --with-openmp=1 --download-suitesparse=1 --download-hypre=1 --download-mumps=1 --download-scalapack=1 --download-blacs=1 --download-ptscotch=1 --download-scotch=1 --download-metis=1 --download-parmetis=1 --download-petsc4py=1 --download-mpi4py=1
What do you have for: ls /home/chaffra/Projects/FEniCS/include Also suggest not using: --with-clanguage=cxx --with-c-support=1 --with-pthreadclasses=1 --with-openmp=1 And there is no more option '--download-blacs=1' Satish On Mon, 28 Sep 2015, Chaffra Affouda wrote:
Hi Barry,
I've erased everything under petsc, clone from git but mumps still won't build. Attached is my configure.log.
Thanks, Chaffra
On 09/25/2015 04:51 PM, Barry Smith wrote:
Cannot explain this. Try deleting the entire PETSc directory and running again with --download-mumps send configure.log if it fails
Barry
On Sep 25, 2015, at 3:29 PM, Chaffra Affouda<[email protected]> wrote:
I cannot build petsc-3.6.1 on ubuntu. I am getting the error below. Is mumps broken here? I am using ubuntu trusty.
make[1]: Leaving directory `petsc-3.6.1/arch-linux2-cxx-opt/externalpackages/MUMPS'mumps_io_basic.c: In function ‘mumps_init_file_name’: mumps_io_basic.c:579:14: warning: assignment discards ‘const’ qualifier from pointer target type [enabled by default] tmp_dir=MUMPS_OOC_DEFAULT_DIR; ^ cmumps_ooc.F:159.42:
OOC_NB_FILE_TYPE=id%OOC_NB_FILE_TYPE 1 Error: 'ooc_nb_file_type' at (1) is not a member of the 'cmumps_struc' structure cmumps_ooc.F:525.36:
DO I1=1,id%OOC_NB_FILE_TYPE 1 Error: 'ooc_nb_file_type' at (1) is not a member of the 'cmumps_struc' structure cmumps_ooc.F:540.12:
ENDDO 1 Error: Expecting END IF statement at (1) cmumps_ooc.F:562.31:
IF(.NOT. id%IF_RESTARTING) CALL CMUMPS_OOC_CLEAN_FILES(id,IERR) 1 Error: 'if_restarting' at (1) is not a member of the 'cmumps_struc' structure cmumps_ooc.F:677.42:
OOC_NB_FILE_TYPE=id%OOC_NB_FILE_TYPE 1 Error: 'ooc_nb_file_type' at (1) is not a member of the 'cmumps_struc' structure make[3]: *** [cmumps_ooc.o] Error 1 make[2]: *** [c] Error 2 make[1]: *** [mumps_lib] Error 2 make: *** [c] Error 2 *******************************************************************************
participants (1)
Satish Balay
