Re: [petsc-dev] kokkos test fail in branch
Ah, there was an old one there. I removed it and I can not compile ex3k. I thought check always rebuilt executables. Now I get a link error: 14:12 barry/2020-11-11/cleanup-matsetvaluesdevice *= /gpfs/alpine/csc314/scratch/adams/petsc/src/snes/tutorials$ make PETSC_DIR=/gpfs/alpine/csc314/scratch/adams/petsc PETSC_ARCH=arch-summit-opt-gnu-kokkos-notpl-cuda10 ex3k PATH=/sw/sources/lsf-tools/2.0/summit/bin:/sw/summit/xalt/1.2.1/bin:/sw/summit/forge/20.0.1/bin:/autofs/nccs-svm1_sw/summit/.swci/1-compute/opt/spack/20180914/linux-rhel7-ppc64le/gcc-6.4.0/spectrum-mpi-10.3.1.2-20200121-awz2q5brde7wgdqqw4ugalrkukeub4eb/bin:/sw/summit/gcc/6.4.0/bin:/sw/summit/cuda/10.1.243/bin:/autofs/nccs-svm1_sw/summit/.swci/0-core/opt/spack/20180914/linux-rhel7-ppc64le/gcc-4.8.5/cmake-3.20.2-24ualfzy6em6ws5sbiu7rlgcuionodrm/bin:/autofs/nccs-svm1_sw/summit/.swci/1-compute/opt/spack/20180914/linux-rhel7-ppc64le/gcc-4.8.5/darshan-runtime-3.1.7-cnvxicgf5j4ap64qi6v5gxp67hmrjz43/bin:/sw/sources/hpss/bin:/opt/ibm/spectrumcomputing/lsf/ 10.1.0.9/linux3.10-glibc2.17-ppc64le-csm/etc:/opt/ibm/spectrumcomputing/lsf/10.1.0.9/linux3.10-glibc2.17-ppc64le-csm/bin:/opt/ibm/csm/bin:/usr/local/bin:/usr/bin:/usr/local/sbin:/usr/sbin:/opt/ibm/flightlog/bin:/opt/ibutils/bin:/opt/ibm/spectrum_mpi/jsm_pmix/bin:/opt/puppetlabs/bin:/usr/lpp/mmfs/bin:`dirname nvcc` NVCC_WRAPPER_DEFAULT_COMPILER=gcc /gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-kokkos-notpl-cuda10/bin/nvcc_wrapper --expt-extended-lambda -Xcompiler -rdynamic -lineinfo -DLANDAU_DIM=2 -DLANDAU_MAX_SPECIES=10 -DPETSC_HAVE_CUDA_ATOMIC -DLANDAU_MAX_Q=4 -Xcompiler -fPIC -O3 -gencode arch=compute_70,code=sm_70 -I/autofs/nccs-svm1_sw/summit/.swci/1-compute/opt/spack/20180914/linux-rhel7-ppc64le/gcc-6.4.0/spectrum-mpi-10.3.1.2-20200121-awz2q5brde7wgdqqw4ugalrkukeub4eb/include -Wno-deprecated-gpu-targets -I/gpfs/alpine/csc314/scratch/adams/petsc/include -I/gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-kokkos-notpl-cuda10/include -I/sw/summit/cuda/10.1.243/include -I/autofs/nccs-svm1_sw/summit/.swci/1-compute/opt/spack/20180914/linux-rhel7-ppc64le/gcc-6.4.0/spectrum-mpi-10.3.1.2-20200121-awz2q5brde7wgdqqw4ugalrkukeub4eb/include -fPIC -g -DLANDAU_DIM=2 -DLANDAU_MAX_SPECIES=10 -DPETSC_HAVE_CUDA_ATOMIC -DLANDAU_MAX_Q=4 -Werror=maybe-uninitialized -O0 ex3k.kokkos.cxx -Wl,-rpath,/gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-kokkos-notpl-cuda10/lib -L/gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-kokkos-notpl-cuda10/lib -Wl,-rpath,/gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-kokkos-notpl-cuda10/lib -L/gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-kokkos-notpl-cuda10/lib -L/autofs/nccs-svm1_sw/summit/.swci/1-compute/opt/spack/20180914/linux-rhel7-ppc64le/gcc-6.4.0/netlib-lapack-3.8.0-wcabdyqhdi5rooxbkqa6x5d7hxyxwdkm/lib64 -Wl,-rpath,/sw/summit/cuda/10.1.243/lib64 -L/sw/summit/cuda/10.1.243/lib64 -lpetsc -lkokkoskernels -lkokkoscontainers -lkokkoscore -lp4est -lsc -lblas -llapack -ltriangle -lm -lz -lcudart -lcufft -lcublas -lcusparse -lcusolver -lcurand -lstdc++ -ldl -o ex3k nvcc_wrapper - *warning* you have set multiple optimization flags (-O*), only the last is used because nvcc can only accept a single optimization setting. */usr/bin/ld: /tmp/tmpxft_0000e0c2_00000000-10_ex3k.kokkos.o: undefined reference to symbol 'ompi_mpi_comm_self'*/autofs/nccs-svm1_sw/summit/.swci/1-compute/opt/spack/20180914/linux-rhel7-ppc64le/gcc-6.4.0/spectrum-mpi-10.3.1.2-20200121-awz2q5brde7wgdqqw4ugalrkukeub4eb/lib/libmpi_ibm.so.3: error adding symbols: DSO missing from command line collect2: error: ld returned 1 exit status make: *** [ex3k] Error 1 On Sat, Jun 5, 2021 at 12:16 PM Junchao Zhang <[email protected]> wrote:
$rm ex3k $make ex3k and run again?
--Junchao Zhang
On Sat, Jun 5, 2021 at 10:25 AM Mark Adams <[email protected]> wrote:
This is posted in Barry's MR, but I get this error with Kokkos-cuda on Summit. Failing to open a shared lib. Thoughts? Mark
11:15 barry/2020-11-11/cleanup-matsetvaluesdevice= /gpfs/alpine/csc314/scratch/adams/petsc$ make PETSC_DIR=/gpfs/alpine/csc314/scratch/adams/petsc PETSC_ARCH=arch-summit-opt-gnu-kokkos-notpl-cuda10 check Running check examples to verify correct installation Using PETSC_DIR=/gpfs/alpine/csc314/scratch/adams/petsc and PETSC_ARCH=arch-summit-opt-gnu-kokkos-notpl-cuda10 C/C++ example src/snes/tutorials/ex19 run successfully with 1 MPI process C/C++ example src/snes/tutorials/ex19 run successfully with 2 MPI processes C/C++ example src/snes/tutorials/ex19 run successfully with cuda gmake[3]: [runex3k_kokkos] Error 127 (ignored) 1,25c1,2 < atol=1e-50, rtol=1e-08, stol=1e-08, maxit=50, maxf=10000 < Vec Object: Exact Solution 2 MPI processes < type: mpikokkos < Process [0] < 0. < 0.015625 < 0.125 < Process [1] < 0.421875 < 1. < Vec Object: Forcing function 2 MPI processes < type: mpikokkos < Process [0] < 1e-72 < 1.50024 < 3.01563 < Process [1] < 4.67798 < 7. < 0 SNES Function norm 5.414682427127e+00 < 1 SNES Function norm 2.952582418265e-01 < 2 SNES Function norm 4.502293658739e-04 < 3 SNES Function norm 1.389665806646e-09 < Number of SNES iterations = 3 < Norm of error 1.49752e-10 Iterations 3 ---
*> ./ex3k: error while loading shared libraries: libpetsc.so.3.015: cannot open shared object file: No such file or directory> ./ex3k: error while loading shared libraries: libpetsc.so.3.015: cannot open shared object file: No such file or directory* /gpfs/alpine/csc314/scratch/adams/petsc/src/snes/tutorials
participants (1)
Mark Adams
