Re: [petsc-dev] configure issues with new MKL and --with-mkl_sparse_optimize=0
On Mon, Dec 3, 2018 at 8:35 PM Mills, Richard Tran via petsc-dev < [email protected]> wrote:
Sorry, everyone, for how long it took me to have time to get back to this. I tried the change I suggested in my previous message, but configure fails with
******************************************************************************* UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for details):
------------------------------------------------------------------------------- Did not find package MKL_SPARSE_OPTIMIZE needed by mkl_sparse_sp2m. Enable the package using --with-mkl_sparse_optimize
Does this happen because I have specified that this is a "look for by default" package? What I'd like to happen is that this package be looked for my default, in fact, but if MKL_SPARSE_OPTIMIZE is not present or disabled, then I'd like the test for mkl_sparse_sp2m to fail gracefully and configure to continue. That is: I don't want the fact that I am looking for this package automatically to imply that it HAS to be there. Is there any easy way to get this behavior?
Put it in the optional packages list. Then check explicitly that it was found in the sp2m configure method. Thanks, Matt
--Richard
On 11/27/18 2:15 PM, Smith, Barry F. wrote:
On Nov 26, 2018, at 6:12 PM, Mills, Richard Tran via petsc-dev <[email protected]> <[email protected]> wrote:
Hi Stefano,
Apologies for the slow reply; I was out for the US Thanksgiving Holiday.
You've found an error in the logic for the MKL configure tests: Your MKL does indeed have mkl_sparse_sp2m(), but since this depends on having mkl_sparse_optimize() and you have specified '--with-mkl_sparse_optimize=0', PETSC_HAVE_MKL_SPARSE_SP2M either ought to not be defined, or in my AIJMKL code I should only enable the SP2M code if PETSC_HAVE_MKL_SPARSE_OPTIMIZE is defined. I think I like the former option better. For those more familiar with BuildSystem than I am, I think I can do this by putting the following in setupDependencies() in mkl_sparse_sp2m.py:
self.mkl_sparse_optimize = framework.require('config.packages.mkl_sparse_optimize', self) self.deps = [self.blasLapack,self.mkl_sparse_optimize]
Looks ok to me. Make a pull request with Satish as a reviewer.
Barry
Is that all that is required?
--Richard
On 11/21/18 10:59 PM, Stefano Zampini wrote:
Richard,
I just noticed that PETSc master does not build with the options
'--with-mkl_pardiso-dir=/soft/com/packages/intel/18/u3/mkl', '--with-mkl_sparse_optimize=0',
This is on frog at MCS, but it will be the same on other machines as the macros configuration
PETSC_HAVE_MKL_SPARSE_OPTIMIZE not defined PETSC_HAVE_MKL_SPARSE_SP2M defined
does not seem to be supported.
/nfs2/szampini/src/petsc/src/mat/impls/aij/seq/aijmkl/aijmkl.c(797): error: struct "<unnamed>" has no field "csrA" csrA = a->csrA;
Could you please take a look? Why is the mkl_sparse_sp2m package flagged as lookforbydefault in the configure scripts?
Thanks -- Stefano
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
participants (1)
Matthew Knepley
