Thanks Matt, Satish. A few issues though. Like you said, the latest cygwin has python 2.6.8 which does not have argparse. When I place the following in path http://argparse.googlecode.com/svn/trunk/argparse.py I can run the python build with 2.6.8. However, the "ar" based build had worked fine and the python based build fails for these two files. src/snes/impls/MULTIB~1/multiblock.c src/snes/impls/vi/rsaug/virsaug.c It looks like these two files were NOT compiled in the ar based build. The two make.log files are attached. One more question. I tried to run the python based build the second time (after it was unsuccessful the first time) and then it deleted all the previous .o files it had created in ARCH/lib/libpetsc-obj. How can that be avoided? Chetan From: [email protected] [mailto:[email protected]] On Behalf Of Matthew Knepley Sent: Thursday, June 28, 2012 1:35 PM To: For users of the development version of PETSc Subject: Re: [petsc-dev] slow "ar Scq" on cygwin On Thu, Jun 28, 2012 at 2:23 PM, Chetan Jhurani <[email protected]> wrote: Hi devs, Is there a way to avoid running the archiver (ar) every time a petsc directory is compiled? The reason I'm asking this is that when libpetsc.lib becomes large enough (say 100MB+, esp. for debug build), "ar Sqc" on cygwin takes very long in each directory. Depending on OS caching, very long can be 10 seconds per PETSc directory just to run ar. It creates a new temp file from scratch, puts stuff from libpetsc.lib and new stuff in it and then renames the temp file. As you can imagine, the compilation process is fast in the beginning but crawls by the end. I've seen the same IO sequence on Linux (with Sqc flags to ar), but since cygwin IO is slower the effect is more clearly visible. Building within a ramdisk leads to 25% faster compilation but it was more of a curiosity. Build with Python. It never uses antique things like ar :) python2.7 ./config/builder2.py build Matt Chetan -- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener
participants (1)
Chetan Jhurani
