Re: [petsc-dev] Multiple MPICH/fblaslapack Installs For Multiple Arches
Yes on all points regarding MPI and BLAS/Lapack. I recommend installing a current MPICH and/or Open MPI system-wide, preferably hooked up to ccache (see replies to this thread: https://lists.mcs.anl.gov/pipermail/petsc-dev/2020-January/025505.html <https://lists.mcs.anl.gov/pipermail/petsc-dev/2020-January/025505.html>), as well as BLAS/Lapack system-wide. It's the other packages that are more likely to depend on int/scalar configuration, but even many of those (HDF5, SuiteSparse, etc.) aren't built specially for PETSc.
Is the home-brew MPICH, openblas, lapack sufficient here? Or is it recommended to build all three from source? Best regards, Jacob Faibussowitsch (Jacob Fai - booss - oh - vitch) Cell: (312) 694-3391
On Mar 22, 2020, at 4:25 PM, Jed Brown <[email protected]> wrote:
Jacob Faibussowitsch <[email protected] <mailto:[email protected]>> writes:
Hello all,
As part of development, I have several arch folders lying around in my PETSC_DIR namely a 32-bit OSX, 64-bit OSX, 32-bit linux with valgrind, 64-bit linux with valgrind, and a 32-bit up to date with current master. All of these have a —download-mpich —download-fblaslapack and hence their own copy of each (so that’s 5 copies of each, plus other duplicated packages im sure). At this stage, even getting the bare minimum of these arches ready for dev work after a rebase/git pull takes decades as package versions, or conf settings change, forcing a rebuild of the same packages multiple times.
My question(s): What petsc ./configure options are necessary to change the configuration of each library w.r.t. petsc? i.e. can my 64-bit arches use my 32-bit MPICH/fblaslapack and vice-versa?
Does this change when I have —with-debug on or off? If so, what other packages have a similar ability? Is there anywhere in ./configure —help where this kind of information would be documented?
I suspect that this hasn’t been fully explored since its primarily a developer “problem” and not one the average user will run into/care about (since they usually aren’t building petsc multiple times). I’m sure everyone has their own ways of tackling this problem, I’d love to hear them.
Best regards,
participants (1)
