Re: New approach for external direct solvers in PETSc
On Jul 25, 2008, at 5:47 PM, Lisandro Dalcin wrote:
BTW, Have you ever considered the posibility of not using the 'Mat' class for factored matrices?? I believe that normal matrices and factored matrices share very few in common as to being instances of the same class. Looking at the source code in src/mat, there are many checks like 'if (mat-->factor)' or 'if (!mat->factor)' that seems to support my concern. What do you think?
After a (tiny) bit more thought I think we really should make this change: pros 1) it will simplify the code a good amount hence less bugs 2) conceptually it makes sense cons 1) requires a large reorganization of the Mat code (will introduce bugs) 2) requires the user to deal with one more PETSc object (MatFactor) But since most users deal with SNES/KSP/PC most users will never see this new object. The question is when/how to make this massive change. It is as big or bigger than the change I already made with MatGetFactor(). Barry
On Fri, Jul 25, 2008 at 7:02 PM, Barry Smith <[email protected]> wrote:
petsc-dev users,
I have finally completed my changes to PETSc for a new approach to accessing external direct solvers in PETSc like Spooles, MUMPS etc. I will be pushing it to petsc-dev sometime the middle of next week. If you are using the direct solvers you might consider cloning from
http://petsc.cs.iit.edu/hg/petsc/petsc-dev-new-solvers or
ssh://[email protected]//hg/petsc/petsc-dev-new-solvers
and trying it out before then. Please report problem to [email protected] as you hit them.
Barry
From the changes file
The "parallel direct solver" matrix types like MATAIJSPOOLES are ALL gone. Now you use -pc_factor_mat_solver_package spooles etc or PCFactorSetMatSolverPackage() or if working directly with matrices, MatGetFactor(A,MATSPOOLES,...)
-- Lisandro Dalc�n --------------- Centro Internacional de M�todos Computacionales en Ingenier�a (CIMEC) Instituto de Desarrollo Tecnol�gico para la Industria Qu�mica (INTEC) Consejo Nacional de Investigaciones Cient�ficas y T�cnicas (CONICET) PTLC - G�emes 3450, (3000) Santa Fe, Argentina Tel/Fax: +54-(0)342-451.1594
participants (1)
Barry Smith
