I think this is complete. http://petsc.cs.iit.edu/petsc/petsc-dev/rev/a36906938641 This was my first time messing with configure. It works in all cases I have tested, let me know if I screwed up. The default alignment is now 16, configurable via --with-memalign. Alignment of pointers compiles to (gcc-4.4.2/x86-64 at all positive optimization levels) lea r9,[r8+rbx*1+0xf] and r9,0xfffffffffffffff0 so there should be no concern over runtime cost of alignment. If the user provides their own malloc (via PetscMallocSet) which does not provide the desired alignment then the first array will not have that alignment (obviously) but every other will. It costs a few extra bytes per allocation but this should only add up to a few kB in real applications. Jed
participants (1)
Jed Brown
