Re: [petsc-dev] questions on new include organization
On Feb 12, 2013, at 11:24 PM, Jed Brown <[email protected]> wrote:
On Tue, Feb 12, 2013 at 11:17 PM, Matthew Knepley <[email protected]> wrote: Yes. PetscSection represents groups of numbers, and you can see the grouping.
IS is a map from (int) -> (int), but PetscSection is a map from (int) -> (int,int) where the pair is interpreted to mean an interval of non-negative extent. If it's any use, an IS could be thought of as the special case (int) -> (int,1).
Is it? Maybe a more general definition of PetscSection would be better as map from (int) -> IS Matt's current usage is very restricted to only contiguous blocks of elements in a group. Need that be it? Should that be it? Barry
What queries "do not just return members of this list" in PETSc section? (That is queries we wish to retain anyways).
For example, you can ask "how many items are in group p?". This is crucial, and the whole point of the structure. I don't see how you can recover that information from just the list of dof numbers.
participants (1)
Barry Smith
