Re: [petsc-dev] Globsearch fails for me when running tests
Sorry for the delay. Fixed in MR !2663. It turns out that the *read* for $(file <...) did not occur until gmake 4.2 so this bit me even on a (admittedly old) Linux dev box. To enable the widest range of usage, I keep a modified version of the current $(shell ...) usage, but have commented out the gmake >4.2 solution for people who want the truly scalable solution (e.g., globsearch='*'). The current fix should work until dm, or other package, gets to around 9K tests which seems to be when globsearch failed. The new solution uses an upgraded `config/query_tests.py` script so is similar to the query/queryval functionality. Scott On 3/28/20 10:34 AM, Satish Balay via petsc-dev wrote:
On Sat, 28 Mar 2020, Jed Brown wrote:
Matthew Knepley <[email protected]> writes:
IIRC, the $(file ...) function does not work with stock make in macOS.
You're right; that is a make 4.0 feature. But developers who need globsearch should have the ability to evade Apple's anti-GNU smear.
Do we really have to make things hard on Mac to use something I use every day hundreds of times?
Are you still using make-3.81? Do you also use an Apple Newton?
You can still use search and searchin.
Scott can implement globsearch to call Python that calls make print-test (listing tests on stdout) and returns the result on stdout. But it can't pass the list all the tests on the command line.
Configure has been printing this warning for a very long time - but its easily ignored..
=============================================================================== ***** WARNING: You have an older version of Gnu make, it will work, but may not support all the parallel testing options. You can install the latest Gnu make with your package manager, such as brew or macports, or use the --download-make option to get the latest Gnu make ***** ===============================================================================
Satish
-- Tech-X Corporation [email protected] 5621 Arapahoe Ave, Suite A Phone: (720) 974-1841 Boulder, CO 80303 Fax: (303) 448-7756
participants (1)
Scott Kruger
