Re: [petsc-dev] no petsc on Edison
Hong, Very nice, thanks! Barry
On Feb 27, 2017, at 2:06 PM, Hong <[email protected]> wrote:
Mark, I implemented scalable MatPtAP and did comparisons of three implementations using ex56.c on alcf cetus machine (this machine has small memory, 1GB/core): - nonscalable PtAP: use an array of length PN to do dense axpy - scalable PtAP: do sparse axpy without use of PN array - hypre PtAP.
The results are attached. Summary: - nonscalable PtAP is 2x faster than scalable, 8x faster than hypre PtAP - scalable PtAP is 4x faster than hypre PtAP - hypre uses less memory (see job.ne399.n63.np1000.sh)
Based on above observation, I set the default PtAP algorithm as 'nonscalable'. When PN > local estimated nonzero of C=PtAP, then switch default to 'scalable'. User can overwrite default.
For the case of np=8000, ne=599 (see job.ne599.n500.np8000.sh), I get MatPtAP 3.6224e+01 (nonscalable for small mats, scalable for larger ones) scalable MatPtAP 4.6129e+01 hypre 1.9389e+02
I'm merging this work to next, then to master soon.
Hong
On Wed, Feb 8, 2017 at 7:25 PM, Mark Adams <[email protected]> wrote: Thanks Hong, that sounds great.
I am weary of silent optimizations like you suggest but 2x is big! and failure is very bad. So I would vote for your suggestion.
ex56 is an elasticity problem. It would be nice, now that you have this experimental setup in place, to compare with hypre on a 3D scalar problem. Hypre might not spend much effort optimizing for block matrices. 3x better than hypre seems large to me. I have to suspect that hypre does not exploit blocked matrices as much as we do.
Thanks again,
On Wed, Feb 8, 2017 at 12:07 PM, Hong <[email protected]> wrote: I conducted tests on MatMatMult() and MatPtAP() using petsc/src/ksp/ksp/examples/tutorials/ex56.c (gamg) on a 8-core machine (petsc machine). The output file is attached.
Summary: 1) non-scalable MatMatMult() for mpiaij format is 2x faster than scalable version. The major difference between the two is dense-axpy vs. sparse-axpy.
Currently, we set non-scalable as default, which leads to problem when running large problems. How about setting default as - non-scalable for small to medium size matrices - scalable for larger ones, e.g.
+ ierr = PetscOptionsEList("-matmatmult_via","Algorithmic approach","MatMatMult",algTypes,nalg,algTypes[1],&alg,&flg);
+ if (!flg) { /* set default algorithm based on B->cmap->N */ + PetscMPIInt size; + ierr = MPI_Comm_size(comm,&size);CHKERRQ(ierr); + if ((PetscReal)(B->cmap->N)/size > 100000.0) alg = 0; /* scalable algorithm */ + }
i.e., if user does NOT pick an algorithm, when ave cols per process > 100k, use scalable implementation; otherwise, non-scalable version.
2) We do NOT have scalable implementation for MatPtAP() yet. We have non-scalable PtAP and interface to Hypre's PtAP. Comparing the two, Petsc MatPtAP() is approx 3x faster than Hypre's.
I'm writing a scalable MatPtAP() now.
Hong
On Thu, Feb 2, 2017 at 2:54 PM, Stefano Zampini <[email protected]> wrote:
Il 02 Feb 2017 23:43, "Mark Adams" <[email protected]> ha scritto:
On Thu, Feb 2, 2017 at 12:02 PM, Stefano Zampini <[email protected]> wrote: Mark,
I saw your configuration has hypre. If you could run with master, you may try -matptap_via hypre.
This is worth trying. Does this even work with GAMG?
Yes, it should work, except that the block sizes, if any, are not propagated to the resulting matrix. I can add it if you need it.
Treb: try hypre anyway. It has its own RAP code.
With that option, you will use hypre's RAP with MATAIJ
It uses BoomerAMGBuildCoarseOperator directly with the AIJ matrices.
Stefano
On Feb 2, 2017, at 7:28 PM, Mark Adams <[email protected]> wrote:
On Thu, Feb 2, 2017 at 11:13 AM, Hong <[email protected]> wrote: Mark: Try '-matmatmult_via scalable' first. If this works, should we set it as default?
If it is robust I would say yes unless it is noticeably slower (say >20%) small scale problems.
<out_ex56_cetus_short>
participants (1)
Barry Smith
