Re: [petsc-dev] Sean is going to love this
Date: Sun, 28 Dec 2014 21:27:21 -0600 From: Barry Smith <[email protected]> To: Sean Farley <[email protected]> Cc: petsc-dev <[email protected]> Subject: Re: [petsc-dev] Sean is going to love this Message-ID: <[email protected]> Content-Type: text/plain; charset="utf-8"
Sean,
brew install /homebrew/science/petsc brew install /homebrew/science/petsc --HEAD --with-x11
Is there any reason not to use home-brew for everything now? Should we be working with the homebrew/science guys to work out the rough edges? (Like their hypre build is sequential and they don't pass the MPI compiler wrappers properly to build packages and ... and ...)
I contributed most of the hypre recipe; brew install hypre --with-mpi should get you a parallel build, and it should also run some parallel exampled as smoke tests. If there's anything missing that should be added, let me know and I can get to it when I return from vacation.
participants (1)
Geoff Oxberry
