Re: [petsc-dev] A closer look at the Xeon Phi
Hi, On 02/12/2013 06:40 PM, Jed Brown wrote:
On Tue, Feb 12, 2013 at 6:06 PM, Tim Tautges <[email protected] <mailto:[email protected]>> wrote:
I'm kind of surprised at the > 10k element crossover myself. For the strong scaling cases, at high core counts, that's not terribly far from the number of DOFS per processor, is it? I guess CPUs will be slower than the Xeon in most cases (BGx), or fewer (Titan), but still.
Which crossover are you referring to? The CPU versus GTX285 at about 20k dofs, but with only very small gains for another order of magnitude?
I assume it's the cross-over of Xeon Phi vs. Xeon, but almost all cross-overs happen in the 10k-100k region and are due to PCI-Express latency. Scaling this to large clusters, replace Xeon Phi by compute node, PCI-Express by GB-Ethernet/Infiniband as well as change the timescale a bit and you're probably not too far off...
For 2D Laplace, we expect to see strong scaling peter out around a couple thousand dofs per core. It can go a little further on Blue Gene because the network is much faster and the cores are a bit slower.
Titan has a lot of (premium price) GPUs that you have to use to utilize the machine well, but it's unclear whether the architecture is delivering a science/dollars advantage, even if you ignore development costs to port and re-tune codes and the environment costs (it's more complicated to build and run, so it takes people longer to get running). I think the main justification is speculation about what future hardware will look like, not cost-effectiveness today.
Once should also keep the influence of TOP500 in mind here. I don't think this machine was primarily built for domain decomposition and the like rather than "approaching Exascale via Linpack". Best regards, Karli
participants (1)
Karl Rupp
