Re: [petsc-dev] Strange issue with testsuite
Scott I found the issue. The programname on this machine has the fullpath, including a matching pattern for the egrep rule. Thanks Il giorno mer 12 mag 2021 alle ore 22:33 Scott Kruger <[email protected]> ha scritto:
It's something like this:
cd arch-debug-uni/tests/sys/tests/runex54_1_options_file-ex54options_1a_wrong/
cat *.tmp # Does anything look fishy? cat diff*.sh # see how diff test with filter is being setup by harness ./diff*.sh # run the diff test
Hopefully you can see what's the problem is in more detail. These error catching tests are tricker to debug than the normal tests.
Scott
On 2021-05-12 16:48, Stefano Zampini did write:
I'm currently trying to build PETSc on a NEC-SX. Apart from other issues, I'm facing the following issue with the testsuite.
[zampins@stork petsc]$ make test s='sys*ex54*1a*' V=1 Using MAKEFLAGS: -- V=1 s=sys*ex54*1a*
arch-debug-uni/tests/sys/tests/runex54_1_options_file-ex54options_1a_wrong.sh
-v ok sys_tests-ex54_1_options_file-ex54options_1a_wrong # /home/zampins/src/petsc/lib/petsc/bin/petsc-mpiexec.uni -n 1 ../ex54 -options_left 0 -options_view -options_file ex54options_1a_wrong 2>&1 | cat > ex54_1_options_file-ex54options_1a_wrong.tmp not ok diff-sys_tests-ex54_1_options_file-ex54options_1a_wrong # Error code: 1 # 1a2 # > [0]PETSC ERROR:
/home/zampins/src/petsc/arch-debug-uni/tests/sys/tests/runex54_1_options_file-ex54options_1a_wrong/../ex54
on a arch-debug-uni named stork by zampins Wed May 12 16:45:46 2021
However, if I run the test directly, I think it produces the proper output to be filtered. How can I debug this?
[zampins@stork tests]$ ./ex54 -options_left 0 -options_view -options_file ex54options_1a_wrong [0]PETSC ERROR: --------------------- Error Message -------------------------------------------------------------- [0]PETSC ERROR: Invalid argument [0]PETSC ERROR: Unknown first token in options file ex54options_1a_wrong line 1: ! [0]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting. [0]PETSC ERROR: Petsc Development GIT revision: v3.15.0-298-g2115278b7a GIT Date: 2021-05-12 14:01:17 +0300 [0]PETSC ERROR: ./ex54 on a arch-debug-uni named stork by zampins Wed May 12 16:46:21 2021 [0]PETSC ERROR: Configure options --FC_LINKER_FLAGS="-Wl,-z -Wl,muldefs" --download-sowing-configure-arguments="CC=ncc CXX=nc++"
--with-blaslapack-lib="[/opt/nec/ve/nlc/2.3.0/lib/liblapack.a,/opt/nec/ve/nlc/2.3.0/lib/libblas_sequential.a]"
--with-cc=ncc --with-cxx=nc++ --with-debugging=1 --with-fc=nfort --with-mpi=0 --with-shared-ld=nld --with-shared-libraries=1 PETSC_ARCH=arch-debug-uni [0]PETSC ERROR: #1 PetscOptionsInsertFilePetsc() at /home/zampins/src/petsc/src/sys/objects/options.c:537 [0]PETSC ERROR: #2 PetscOptionsInsertFile() at /home/zampins/src/petsc/src/sys/objects/options.c:645 [0]PETSC ERROR: #3 PetscOptionsInsertArgs() at /home/zampins/src/petsc/src/sys/objects/options.c:684 [0]PETSC ERROR: #4 PetscOptionsInsert() at /home/zampins/src/petsc/src/sys/objects/options.c:907 [0]PETSC ERROR: #5 PetscInitialize() at /home/zampins/src/petsc/src/sys/objects/pinit.c:1024
-- Stefano
-- Scott Kruger Tech-X Corporation [email protected] 5621 Arapahoe Ave, Suite A Phone: (720) 466-3196 Boulder, CO 80303 Fax: (303) 448-7756
-- Stefano
participants (1)
Stefano Zampini
