Re: [petsc-dev] [petsc-users] petsc git next branch *is* unwound!
What is meant by the phrase "petsc git next branch is unwound"? What git commands are run to do this? And how is the next branch different when it is unwound from immediately before it is unwound? Thanks, Dave -- Dave Nystrom LANL HPC-5 Phone: 505-667-7913 Email: [email protected] Smail: Mail Stop B272 Group HPC-5 Los Alamos National Laboratory Los Alamos, NM 87545 ________________________________________ From: Nystrom, William David Sent: Thursday, October 02, 2014 10:57 AM To: petsc-users; [email protected] Cc: Nystrom, William David Subject: RE: [petsc-dev] [petsc-users] petsc git next branch *is* unwound! On my local machine I have my master, bare git repo with the following config file which Jed suggested a year or so ago: % cat config [core] repositoryformatversion = 0 filemode = true bare = true sharedrepository = 1 [receive] denyNonFastforwards = true [remote "origin"] url = https://bitbucket.org/petsc/petsc fetch = +refs/heads/maint:refs/heads/maint fetch = +refs/heads/master:refs/heads/master fetch = +refs/heads/next:refs/heads/next [remote "artab"] url = ssh://ml-fey.lanl.gov/usr/projects/artab/users/wdn/repos/git/petsc fetch = +refs/*:refs/* mirror = true And for my workflow, I stay in sync with the official PETSc git repo by periodically executing the following command: git remote -v update origin And then I have various git clones from my master git repo where I do actual work. Do I need to do anything special now that the "next" branch has been unwound with either my master git repo or my git clones? In my master git repo, I have 3 additional branches - wdn_mods_next, wdn_mods_master and wdn_mods_maint where I keep any of my own modifications to those respective branches. And I keep wdn_mods_next in sync with next by periodically executing the following commands in a git clone with the wdn_mods_next branch checked out: git pull origin next resolve any conflicts and commit git push origin wdn_mods_next:wdn_mods_next So, if I do the following set of steps, should I expect them to work now that next has been unwound? 1. cd to my master bare petsc repo git remote -v update origin 2. cd to my git clone of petsc with wdn_mods_next branch checked out git pull origin next resolve any conflicts and commit git push origin wdn_mods_next:wdn_mods_next Thanks, Dave -- Dave Nystrom LANL HPC-5 Phone: 505-667-7913 Email: [email protected] Smail: Mail Stop B272 Group HPC-5 Los Alamos National Laboratory Los Alamos, NM 87545 ________________________________________ From: [email protected] [[email protected]] on behalf of Satish Balay [[email protected]] Sent: Thursday, October 02, 2014 7:38 AM To: [email protected]; [email protected] Subject: Re: [petsc-dev] [petsc-users] petsc git next branch *is* unwound! On Thu, 2 Oct 2014, Satish Balay wrote:
petsc git users,
If you are using next branch from git repository for integration or testing or working with it in some form - i.e if you have 'next' listed by:
git branch
Please delete and recreate it. i.e:
git checkout master git branch -D next git checkout next
From my check - the following feature branches are currently in next (not yet merged to master).
Feature branch owners, please remerge your feature branches into to next - as you see fit.
BTW: Some of you might want to rebase/cleanup some of the feature branches before merging to new next. Also some of these feature branches are from pre-petsc-3.5 timeframe. So a rebase to latest master might be something to consider. [if they are still in line for a merge to master] Satish
$ comm -12 <(git branch -r --merged next | sort) <(git branch -r --no-merged master | sort) origin/barry/cleanup-blaslapack origin/barry/remove-dreal origin/barry/remove-sidl origin/barry/reuse-hwloc origin/dmeiser/pullrequest-fix-cusp-bjacobi2 origin/dmeiser/pullrequest-remove-thrust-py origin/jed/sr-driver4 origin/jed/vecghostgetvalues origin/karlrupp/fix-viennacl-veccopy origin/karpeev/fix-ksp-pcgasm origin/knepley/feature-optcontrol-mg origin/knepley/feature-plex-generator-args origin/knepley/feature-plex-nasm origin/knepley/fix-configure-petsc-dep origin/knepley/fix-quadrature-order origin/madams/sr-driver4 origin/maint origin/mlange05/fix-gmsh-coordinates origin/next origin/paulmullowney/aijcusp-ellpack-fix origin/prbrune/sf-examplefix origin/prbrune/snes-ex19vtkoutput origin/sarich/fix-tao-jbearing-bqpip origin/shri/ts-dae-semi-explicit origin/shri/ts-is-for-differential-variables origin/shri/ts-powergrid origin/stefano_zampini/matis-preallocation origin/stefano_zampini/pcbddc-changeofbasis origin/stefano_zampini/pcbddc_deluxe origin/tisaac/feature-fe-geom-dim origin/tisaac/plex-flexible-projection
[obviously remove maint, next from the above list]
The previous 'next' branch is currently available as 'next-oct-2014' - if you need it for any checks/debugging.
Satish
participants (1)
