Re: [petsc-dev] plex test 26 failing for complex
On Oct 24, 2018, at 9:03 AM, Matthew Knepley <[email protected]<mailto:[email protected]>> wrote: On Wed, Oct 24, 2018 at 9:54 AM Hapla Vaclav <[email protected]<mailto:[email protected]>> wrote: Tests dm_impls_plex_tests-ex26% fail for exodusii+complex build. E.g. not ok dm_impls_plex_tests-ex26_15 # [0]PETSC ERROR: --------------------- Error Message -------------------------------------------------------------- # [0]PETSC ERROR: Petsc has generated inconsistent data # [0]PETSC ERROR: UAlpha ||Vin - Vout|| = 1000.56 # # [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting. # [0]PETSC ERROR: Petsc Development GIT revision: v3.10.1-219-g632bab2 GIT Date: 2018-10-24 12:51:19 +0200 # [0]PETSC ERROR: ../ex26 on a arch-linux-gcc-complex-single-64idx named swp-group-pc by vhapla Wed Oct 24 15:43:20 2018 # [0]PETSC ERROR: Configure options --download-c2html --download-f2cblaslapack --download-exodusii --download-hdf5 --download-metis --download-netcdf --download-pnetcdf --download-parmetis --download-ptscotch --download-ctetgen --with-64-bit-indices --download-zlib --with-cc=mpicc --with-cxx=mpicxx --with-fc=mpifort --with-precision=single --with-python=1 --with-scalar-type=complex --with-shared-libraries=1 --with-valgrind-dir=/home/vhapla PETSC_ARCH=arch-linux-gcc-complex-single-64idx # [0]PETSC ERROR: #1 main() line 387 in /home/vhapla/petsc-1/src/dm/impls/plex/examples/tests/ex26.c Should this be fixed or "requires: !complex" added? Yes. This is Blaise's test, and I do not know if it was intended to work with complex. No, it is not. Blaise Thanks, Matt Is this configuration not covered by nightly tests? Vaclav -- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/~knepley/> -- Department of Mathematics and Center for Computation & Technology Louisiana State University, Baton Rouge, LA 70803, USA Tel. +1 (225) 578 1612, Fax +1 (225) 578 4276 http://www.math.lsu.edu/~bourdin
participants (1)
Blaise A Bourdin
