Re: [petsc-dev] [petsc-checkbuilds] PETSc blame digest (next) 2016-04-08
I pushed the following to get suppress this warning to tisaac/dmp4est-feature-injection [and merged to next] https://bitbucket.org/petsc/petsc/commits/403a37bcd7a8acbd8d9c14f7e483574a3c... [preferable to the alternative of trying to filter out the warning during post-processing] Satish On Wed, 13 Apr 2016, Satish Balay wrote:
ok - I mixed up DMPlexReferenceTreeRestoreChildrenMatrices_Injection and DMPlexReferenceTreeGetChildrenMatrices_Injection
Satish
On Tue, 12 Apr 2016, Tobin Isaac wrote:
On Tue, Apr 12, 2016 at 10:42:26PM -0500, Satish Balay wrote:
Ok - I see the bug in this code.
static PetscErrorCode DMPlexReferenceTreeRestoreChildrenMatrices_Injection(DM refTree, Mat inj, PetscScalar ****childrenMats)
Since this funciton is defined as 'static' the compiler is doing 'inter procedure analysis' across the calling function with -O [this warning comes up only with -O build]
1. plextree.c:3506 has the following variable declared [uninitialized] PetscScalar ***childrenMats;
2. the next usage of this variable is: plextree.c:3846 ierr = DMPlexReferenceTreeGetChildrenMatrices_Injection(refTree,injRef,&childrenMats);CHKERRQ(ierr);
3. Within this function - the first usage of this variable is plextree.c:L3453 refPointFieldMats = *childrenMats;
i.e access/use of uninitialized variable.
The following supresses the warning - but there is clearly some lurking bug..
A bug in the code, or the analyzer? Like I said, there is a conditional-free path that leads to plextree.c:L3436 (was 3437)---
*childrenMats = refPointFieldMats;
---in the Get function before the line in the Restore function that's triggering the warning. Maybe the (shorter) Restore function is being inlined while the Get function isn't, I don't know, but I'm fairly confident this is a false positive.
Furthermore, this code is covered by tests in next, but looking at the dashboard I don't see any warnings from the valgrind build.
diff --git a/src/dm/impls/plex/plextree.c b/src/dm/impls/plex/plextree.c index 2ee02d0..e51f704 100644 --- a/src/dm/impls/plex/plextree.c +++ b/src/dm/impls/plex/plextree.c @@ -3503,7 +3503,7 @@ PetscErrorCode DMPlexComputeInjectorTree(DM coarse, DM fine, PetscSF coarseToFin PetscLayout rowMap, colMap; PetscInt rowStart, rowEnd, colStart, colEnd, *nnzD, *nnzO; PetscObject injRefObj; - PetscScalar ***childrenMats; + PetscScalar ***childrenMats=0; PetscErrorCode ierr;
PetscFunctionBegin;
And this was introduced by http://bitbucket.org/petsc/petsc/commits/f30e825d
Satish
On Fri, 8 Apr 2016, Barry Smith wrote:
Toby,
We'll be filtering out these false positives. It is just taking us a couple of days to determine that needs to be filtered.
Barry
On Apr 8, 2016, at 2:36 PM, Tobin Isaac <[email protected]> wrote:
I spent a couple minutes verifying that there is no code path where that variable is not initialized on line 3437.
-Wmaybe-uninitialized seems to generate a lot of false positives. Coupled with the blame digest's poor ability to assign blame, this proactive approach seems to waste more time than a reactive SEGV->valgrind->fix approach.
Cheers, Toby
On Fri, Apr 08, 2016 at 02:12:22PM -0500, Satish Balay wrote:
This should have been sent to Toby.
I don't really understand the issue here. Its triggered by --with-debugging=0. I'm not sure why these compilers are pointing to petscsys.h. I get slightly different message on my laptop.
mpicc -c -fPIC -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -fvisibility=hidden -g -O -I/home/balay/petsc/include -I/home/balay/petsc/arch-linux2-c-opt/include -I/home/balay/soft/mpich-3.1.4/include -MMD -MP /home/balay/petsc/src/dm/impls/plex/plextree.c -o arch-linux2-c-opt/obj/src/dm/impls/plex/plextree.o /home/balay/petsc/src/dm/impls/plex/plextree.c: In function ‘DMPlexComputeInjectorTree’: /home/balay/petsc/src/dm/impls/plex/plextree.c:3484:11: warning: ‘childrenMats’ may be used uninitialized in this function [-Wmaybe-uninitialized] ierr = PetscFree(refPointFieldMats);CHKERRQ(ierr); ^ /home/balay/petsc/src/dm/impls/plex/plextree.c:3507:18: note: ‘childrenMats’ was declared here PetscScalar ***childrenMats; ^
Satish
On Fri, 8 Apr 2016, PETSc checkBuilds wrote:
Dear PETSc developer,
This email contains listings of contributions attributed to you by `git blame` that caused compiler errors or warnings in PETSc automated testing. Follow the links to see the full log files. Please attempt to fix the issues promptly or let us know at [email protected] if you are unable to resolve the issues.
Thanks, The PETSc development team
warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/49d7da5 PetscMalloc: allow ptr=malloc(0) and free(ptr)
include/petscsys.h:1157 [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2016/04/08/build_next_a...] /usr/home/balay/petsc.clone-2/include/petscsys.h:1157:88: warning: 'childrenMats' may be used uninitialized in this function [-Wmaybe-uninitialized] [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2016/04/08/build_next_a...] /sandbox/petsc/petsc.clone-3/include/petscsys.h:1157:88: warning: 'childrenMats' may be used uninitialized in this function [-Wmaybe-uninitialized] [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2016/04/08/build_next_a...] /usr/home/balay/petsc.clone/include/petscsys.h:1157:39: warning: 'childrenMats' may be used uninitialized in this function [-Wmaybe-uninitialized] [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2016/04/08/build_next_a...] /sandbox/petsc/petsc.clone-4/include/petscsys.h:1157:25: warning: 'childrenMats' may be used uninitialized in this function [-Wmaybe-uninitialized] [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2016/04/08/build_next_a...] /sandbox/petsc/petsc.clone/include/petscsys.h:1157:25: warning: 'childrenMats' may be used uninitialized in this function [-Wmaybe-uninitialized]
---- To opt-out from receiving these messages - send a request to [email protected].
participants (1)
Satish Balay
