Re: [petsc-dev] MatCreateVecs interface
pushed a fix https://bitbucket.org/petsc/petsc/commits/ae287a2e7a141494f7c41f9dd537addb63... However, it appears that the functions below for CUSP, CUSPARSE and VIENNACL are mere copies of the interface. What about defining the type of the Vec in the interface and get rid of these? src/mat/impls/aij/mpi/mpicusp/mpiaijcusp.cu: A->ops->getvecs = MatCreateVecs_MPIAIJCUSP; src/mat/impls/aij/mpi/mpicusparse/mpiaijcusparse.cu: A->ops->getvecs = MatCreateVecs_MPIAIJCUSPARSE; src/mat/impls/aij/mpi/mpiviennacl/mpiaijviennacl.cxx: A->ops->getvecs = MatCreateVecs_MPIAIJViennaCL; src/mat/impls/aij/seq/seqcusp/aijcusp.cu: B->ops->getvecs = MatCreateVecs_SeqAIJCUSP; src/mat/impls/aij/seq/seqcusparse/aijcusparse.cu: B->ops->getvecs = MatCreateVecs_SeqAIJCUSPARSE; src/mat/impls/aij/seq/seqviennacl/aijviennacl.cxx: B->ops->getvecs = MatCreateVecs_SeqAIJViennaCL; Stefano On Jun 25, 2015, at 4:34 PM, Barry Smith <[email protected]> wrote:
I think you are right, go ahead and make a pull request or send a patch
Barry
On Jun 25, 2015, at 9:43 AM, Stefano Zampini <[email protected]> wrote:
Why the current interface in MatCreateVecs requires that a matrix has been already either allocated or setup ? Shouldn’t be enough to check if the layout has been already setup?
Stefano
participants (1)
Stefano Zampini
