Scorched earth did not work: "VecCreate(ompi_communicator_t*, _p_Vec**)", referenced from: PetscLinearSolver<LevelData<FArrayBox> >::solveprivate(LevelData<FArrayBox>&, LevelData<FArrayBox> const&) in libamrelliptic2d.Darwin.g++-4.gfortran.DEBUG.OPT.PETSC.a(PetscLinearSolver.o) "_ompi_mpi_comm_self", referenced from: _ompi_mpi_comm_self$non_lazy_ptr in libamrelliptic2d.Darwin.g++-4.gfortran.DEBUG.OPT.PETSC.a(PetscLinearSolver.o) On Nov 22, 2011, at 11:47 AM, Satish Balay wrote:
Something is strange.
I'll suggeset
rm -rf externalpackages arch-macosx-gnu-seq
and then doing a fresh build.
And then verifying the build with 'make test'
If 'make test' works - and the application build is not working- I'd like to see the complete compile log thats producing this error.
wrt libmpiuni.a - all the relavent stuff is added to libpetsc.a and a separate libmpiuni.a is not created.
Satish
On Tue, 22 Nov 2011, Mark F. Adams wrote:
I'm trying to build a non MPI code and get this error:
Undefined symbols: "_ompi_mpi_comm_self", referenced from: _ompi_mpi_comm_self$non_lazy_ptr in libamrelliptic2d.Darwin.g++-4.gfortran.DEBUG.OPT.PETSC.a(PetscLinearSolver.o) (maybe you meant: _ompi_mpi_comm_self$non_lazy_ptr)
In the past I have linked libmpiuni.a but that did not seem to get created. Did libmpiuni.a go away or did my make fail ...
participants (1)
Mark F. Adams
