Re: [petsc-dev] Backend independent VecGetArray for GPUs
On 10/17/2014 09:45 AM, Lisandro Dalcin wrote:
On 17 October 2014 17:54, Dominic Meiser <[email protected]> wrote:
Hi Ashwin,
Are you suggesting that `VecGetGPUArray*` be added to the `Vec` interface? That might be problematic because these methods only makes sense for GPU vectors. The interface of `Vec` would then be tied to the PETSc configuration.
These methods could be always available simply generate an error for non-GPU vector types. That's a possible approach. Barry, Jed, what's the preferred way of doing this? Make base class interface wider or subtyping via compose and query?
An alternative might be to compose the various `VecCUSPGetArray` and related methods with `Vec` objects. You could then query these methods and use them if available (and handle absence of the methods if needed, e.g. throw an exception). This would be easy to add.
Yes, however note that what we really need is a backend-independent way to get the RAW pointer to the GPU buffers. Right now we have calls to get the CUSP or ViennaCL array, to handle them you need C++ and depend on CUDA/OpenCL at compile-time.
In what sense should it be backend-independent? The method name should be independent of the backend? Or the presence of the method should be backend independent? I don't see what your gaining by having the methods in Vec. You still need to handle the error that occurs if you're dealing with a non-GPU vector and you still have to know the vector type in order to interpret the return value (device pointer vs OpenCL buffer). Dominic -- Dominic Meiser Tech-X Corporation 5621 Arapahoe Avenue Boulder, CO 80303 USA Telephone: 303-996-2036 Fax: 303-448-7756 www.txcorp.com
participants (1)
Dominic Meiser
