Re: how do you access the nonzero elements in SeqAIJ matrices
On Aug 4, 2008, at 3:14 AM, Ahmed El Zein wrote:
I am working on a project where I would like to copy a sparse matrix in CSR format.
I have tried MatGetRow() which works OK but I would really like to get pointers to the 3 arrays directly.
I also tried MatGetRowIJ() which allows me to get the i and j arrays but I can't see how to access the nonzero elements.
and finally I attempted to access the arrays directly like this: Mat_SeqAIJ *a = (Mat_SeqAIJ*)A->data; MatScalar *val = a->a; PetscInt *ptr = a->i; PetscInt *ind = a->j;
Make sure this is a MPI_SeqAIJ matrix. It is only valid to access this data after you have put the values into the matrix and called MatAssemblyBegin() and MatAssemblyEnd(). If you are creating a matrix from i, j, and a look at MatCreateSeqAIJWithArrays() Barry
However when accessing directly I get different values for ptr and SIGSEGV when accessing val or ind.
also I get a bogus number for a->nz (134630032 instead of 21)
Can someone please explain when I am doing wrong?
Ahmed
participants (1)
Barry Smith
