Re: [petsc-dev] [petsc-users] FETI-DP
Jed Brown wrote:
I'm confuse because in the work of Klawoon/Rheinbach, it is claimed that the following operator can be solved in a pure local way:
F = \sum_{i=1}^{N} B^i inv(K_BB^i) trans(B^i)
Did they use "F" for this thing? Usually F is the FETI-DP operator which involves a Schur complement of the entire partially assembled operator in the dual space. In any case, this thing is not purely local since the jump operators B^i need neighboring values so it has the same communication as a MatMult.
"F" is here the usual FETI-DP operator. I just omitted the coarse space part for more readability.
With B^i the jump operators and K_BB^i the discretization of the sub domains with the primal nodes.
I think you mean "with the primal nodes removed".
Yes!
From the notation it follows that EACH local solve takes the whole vector of Lagrange multipliers. But this is not applicable for a good parallel implementation. Any hint on this topic would be helpful for me to understand this problem.
I can't tell from their papers how B is stored. It would be natural to simply store B as a normal assembled matrix with a standard row partition of the Lagrange multipliers. Then you would apply the subdomain solve operator using
MatMultTranspose(B,XLambdaGlobal,XGlobal); for (i=0; i<nlocalsub; i++) { Vec XSubdomain,YSubdomain; VecGetSubVector(XGlobal,sublocal[i],&XSubdomain); // no copy if subdomains are contiguous VecGetSubVector(YGlobal,sublocal[i],&YSubdomain); // also no copy KSPSolve(kspK_BB[i],XSubdomain,YSubdomain); // purely local solve, often KSPPREONLY and PCLU VecRestoreSubVector(XGlobal,sublocal[i],&XSubdomain); VecRestoreSubVector(YGlobal,sublocal[i],&YSubdomain); } MatMult(B,YGlobal,YLambdaGlobal);
All the communication is in the MatMultTranspose and MatMult. The "Global" vectors here are global with respect to K_BB (interior and interface dofs, primal dofs removed). I don't think there is need to ever store K_BB as a parallel matrix, it would be a separate matrix per subdomain (in the general case, subdomains could be parallel on subcommunicators).
This code should handle nlocalsub subdomains owned by the local communicator, typically PETSC_COMM_SELF. The index sets (IS) in sublocal represent the global (space of K_BB) dofs, usually these are contiguous sets so they can be represented very cheaply.
Following the mathematical representation wouldn't make it more sense to store B but B^T, because the local matrices B_i^T are real local and would have no off-diagonal elements? Also the very first multiplication MatMult(B,XLambdaGlobal,XGlobal) could be done in a local way. But I'm not sure what will than happen with the very last matrix multiplication, MatMultTranspose(B,YGlobal,YLambdaGlobal). Would it potentially result in an all-to-all communication?
participants (1)
Thomas Witkowski
