Re: [petsc-dev] petsc-dev on bitbucket
8 Feb
8 Feb
'12
11:36 a.m.
Generally you want fewer people with root access the closer you get to the root directory since the more harm they can do. So for example petsc/releases would only have Satish and one other with admin.
Which is perfectly fine and easy to set up now. Hell, if you *really* want to, just create the account: petsc-release(s) then the URL would be http://bitbucket.org/petsc-release/petsc-3.1
5299
Age (days ago)
5299
Last active (days ago)
0 comments
1 participants
participants (1)
Sean Farley
