Re: [petsc-dev] navigating gitlab
On Mon, Jan 18, 2021 at 8:59 AM Matthew Knepley <[email protected]> wrote:
On Mon, Jan 18, 2021 at 8:23 AM Mark Adams <[email protected]> wrote:
BTW, how do you get that URL? I searched commits for it and did not find it.
Anyway, that bisect failed because I had an error in my verification test (that has since been fixed). I now get this.
Barry: This commit seems to break my cuda Landau code. I'm guessing that I need to change my configure script attached. Any ideas?
Send the configure.log. Barry put output there that will let us see what it is doing.
Matt
Thanks, Mark
08:06 (7ba7a81...)|BISECTING /gpfs/alpine/csc314/scratch/adams/petsc$ git bisect bad 7ba7a8179202d83658a309df68e2ebc2037284d4 is the first bad commit commit 7ba7a8179202d83658a309df68e2ebc2037284d4 Author: Barry Smith <[email protected]> Date: Thu Dec 31 00:28:23 2020 -0500
The previous code passed options for the PETSc C, C preprocessor and CXX compiler to the ccbin compiler used by nvcc even if it was a completely different compiler and the arguments caused the compiler to error with unknown arguments.
This has been an outstanding problem for years, this is the first crude attempt to fix it by not passing the arguments unless the compiler is identical to the PETSc compiler
TODO: have a better check that the compilers are the same TODO: provide a systematic way for the user to provide the compiler used by nvcc, perhaps default to the compiler used by PETSc?
/spend 3.5h Thanks-to: Jose E. Roman <[email protected]>
Fix typo in list of c99 flags
Add error message regarding Intel compilers breaking Gnu compilers when c99 test fails with gcc.
Eventually we may want more systematic checks of Intel compilers breaking Gnu compilers
/spend 15m
:040000 040000 b4d44a220b09ceebb8020979eebf1b98da41e3ab f24913d3614f54de6dfa49a789325f2c71c9983f M config :100644 100644 9e53e76f9a4960cd943304f56bd1a8a10a3ae516 5309077a5a107b3f553b7875ad2a19c17741655b M gmakefile.test :040000 040000 717c9a395a53442fe6917c0aa033b61d3427fbb2 aa365576e1efa7f29d8817c69d03e1983612caa1 M lib(base) 08:16 ~$
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener
participants (1)
Mark Adams
