Re: [petsc-dev] error with --download-amgx
Also - its best to avoid -Werror in externalpackage builds..
Hmm, my branch uses the CMake package to do the install (it has no custom code) so is this a bug in package.py that it doesn't strip out the -Werror when passing stuff to cmake? There is not enough information your email for me to determine where this message you printed below came from. Did it come from my branch? Barry
On Dec 3, 2019, at 9:29 PM, Balay, Satish <[email protected]> wrote:
autofs/nccs-svm1_sw/summit/.swci/0-core/opt/spack/20180914/linux-rhel7-ppc64le/gcc-4.8.5/cmake-3.15.2-xit2o3iepxvqbyku77lwcugufilztu7t/bin/cmake -E remove /autofs/nccs-svm1_home1/adams/petsc/arch-summit-opt64-gnu-cuda/externalpackages/git.amgx/petsc-build/core/CMakeFiles/amgx_core.dir/src/classical/interpolators/./amgx_core_generated_common.cu.o /sw/summit/cuda/10.1.168/bin/nvcc -M -D__CUDACC__ /autofs/nccs-svm1_home1/adams/petsc/arch-summit-opt64-gnu-cuda/externalpackages/git.amgx/plugin_config.cu -o /autofs/nccs-svm1_home1/adams/petsc/arch-summit-opt64-gnu-cuda/externalpackages/git.amgx/petsc-build/base/CMakeFiles/amgx_base.dir/__/amgx_base_generated_plugin_config.cu.o.NVCC-depend -m64 -Xcompiler ,\"-fstack-protector\",\"-g\",\"-O2\",\"-fPIC\",\"-Wno-terminate\",\"-static-libgcc\",\"-fopenmp\",\"-DRAPIDJSON_DEFINED\",\"-DAMGX_WITH_MPI\",\"-fstack-protector\",\"-g\",\"-O2\",\"-fPIC\" -ccbin mpicxx -gencode=arch=compute_35,code=\"sm_35,compute_35\" -gencode=arch=compute_52,code=\"sm_52,compute_52\" -gencode=arch=compute_60,code=\"sm_60,compute_60\" -gencode=arch=compute_70,code=\"sm_70,compute_70\" -O3 -DNDEBUG -std=c++11 --Werror cross-execution-space-call -DNVCC -I/autofs/nccs-svm1_home1/adams/petsc/arch-summit-opt64-gnu-cuda/externalpackages/git.amgx/../../thrust -I/autofs/nccs-svm1_home1/adams/petsc/arch-summit-opt64-gnu-cuda/externalpackages/git..amgx/base/include -I/sw/summit/cuda/10.1.168/include -I/autofs/nccs-svm1_home1/adams/petsc/arch-summit-opt64-gnu-cuda/externalpackages/git.amgx/external/rapidjson/include -- Removing /autofs/nccs-svm1_home1/adams/petsc/arch-summit-opt64-gnu-cuda/externalpackages/git.amgx/petsc-build/base/CMakeFiles/amgx_base.dir/src/./amgx_base_generated_device_properties.cu.o <<<<<<
Satish
On Tue, 3 Dec 2019, Mark Adams wrote:
Barry,
First, there is a fix that we need in the AMGx repo (appended).
I've never had problems like this not being able to build. I will try to build my AMGx manually to check.
21:31 master *= ~/AMGX$ git diff diff --git a/base/include/amgx_c_wrappers.inl b/base/include/amgx_c_wrappers.inl index 42496f0..ed9f0e1 100644 --- a/base/include/amgx_c_wrappers.inl +++ b/base/include/amgx_c_wrappers.inl @@ -643,7 +643,7 @@ inline AMGX_Mode get_mode_from(const Envelope &envl) { //throws... // - FatalError("Mode not found.\n", AMGX_ERR_BAD_MODE); + // FatalError("Mode not found.\n", AMGX_ERR_BAD_MODE); }
AMGX_Mode mode = static_cast<AMGX_Mode>(itFound->second); @@ -1125,4 +1125,4 @@ inline bool remove_managed_matrix(AMGX_matrix_handle envl) } //namespace unnamed
On Tue, Dec 3, 2019 at 8:50 PM Smith, Barry F. <[email protected]> wrote:
The first error is
nvcc error : 'cicc' died due to signal 9 (Kill signal) nvcc error : 'cicc' died due to signal 9 (Kill signal)
later
/autofs/nccs-svm1_home1/adams/petsc/arch-summit-opt64-gnu-cuda/externalpackages/git.amgx/base/src/ amgx_c_common.cu(77): catastrophic error: error while writing generated C++ file: Cannot allocate memory
1 catastrophic error detected in the compilation of "/tmp/tmpxft_000038d3_00000000-4_amgx_c_common.cpp4.ii".
Whatever machine you are compiling on seems to be overloaded. What does top show? Can you log into "different" compiler servers on Summit?
I run the install on the utk system with no problems like this.
PETSc configure is deciding
TEST configureMakeNP from config.packages.make(/autofs/nccs-svm1_home1/adams/petsc/config/BuildSystem/config/packages/make.py:168) TESTING: configureMakeNP from config.packages.make(config/BuildSystem/config/packages/make.py:168) check no of cores on the build machine [perhaps to do make '-j ncores'] module multiprocessing found 128 cores: using make_np = 59 Defined make macro "MAKE_NP" to "59" Defined make macro "MAKE_TEST_NP" to "49" Defined make macro "MAKE_LOAD" to "166.4" Defined make macro "NPMAX" to "128"
then somehow this gets passed down to the AMGX cmake. Perhaps you could try less greedy numbers.
Executing: /usr/bin/gmake -j59 -l166.4
Perhaps try
--with-make-np=20
--with-make-load=20
Barry
On Dec 3, 2019, at 4:17 PM, Mark Adams <[email protected]> wrote:
That might have been from an old .nsf file. Here is a new one. I'm sure I have the disk space.
On Tue, Dec 3, 2019 at 4:51 PM Mark Adams <[email protected]> wrote: Humm, clean up and seem to have different error:
On Tue, Dec 3, 2019 at 3:45 PM Matthew Knepley <[email protected]> wrote: Could you have run out of disk space?
/usr/bin/ranlib: libamgx_base.a: Input/output error gmake[2]: *** [base/libamgx_base.a] Error 1 gmake[2]: *** Deleting file `base/libamgx_base.a' gmake[1]: *** [base/CMakeFiles/amgx_base.dir/all] Error 2 gmake: *** [all] Error 2
Matt
On Tue, Dec 3, 2019 at 1:44 PM Mark Adams <[email protected]> wrote:
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/ <configure.log>
participants (1)
Smith, Barry F.
