Re: [petsc-dev] MatMatMult gives different results
Perhaps this should be on the other bitbucket thread. On Thu, 9 Feb 2012, Jed Brown wrote:
So we have some confusion right now because Matt is pushing to bitbucket first and Barry is pushing to petsc.cs.iit.edu. I would be happy to experiment with using bitbucket as the primary for petsc-dev and have petsc.cs.iit.edu be the mirror (so users can keep tracking petsc-dev without changing URLs).
Is it possible to add such a trigger to bitbucket?
The simple convenience of having https:// and ssh:// trivially push/pull the same repository is enough to make me prefer interacting with bitbucket (screwy networks filter ssh).
Not sure what problems you had. The only known issue with ssh is - we have fail2ban running on petsc.cs.iit - and when there are ssh connections from misconfigured ip adresses [where dns lookup does not work - it thinks its a breakin attempt - and tries to ban that access].
But "two-way mirror" does not work, so we have to agree about where we are pushing.
yeah - we should figureout which is the primary - and all should use that. Satish
participants (1)
Satish Balay
