Re: [petsc-dev] Question about MPICH device we use
On Thu, Jul 23, 2020 at 11:35 PM Satish Balay via petsc-dev < [email protected]> wrote:
On Thu, 23 Jul 2020, Jeff Hammond wrote:
Open-MPI refuses to let users over subscribe without an extra flag to mpirun.
Yes - and when using this flag - it lets the run through - but there is still performance degradation in oversubscribe mode.
I think Intel MPI has an option for blocking poll that supports oversubscription “nicely”.
What option is this? Is it compile time option or something for mpiexec?
I only found configure time options, --enable-nemesis-dbg-nolocal, alias for --enable-dbg-nolocal --enable-dbg-nolocal enables debugging mode where shared-memory communication is disabled Satish
MPICH might have a “no local” option that disables shared memory, in which case nemesis over libfabric with the sockets or TCP provider _might_ do the right thing. But you should ask MPICH people for details.
Jeff
On Thu, Jul 23, 2020 at 12:40 PM Jed Brown <[email protected]> wrote:
I think we should default to ch3:nemesis when --download-mpich, and only do ch3:sock when requested (which we would do in CI).
Satish Balay via petsc-dev <[email protected]> writes:
Primarily because ch3:sock performance does not degrade in oversubscribe mode - which is developer friendly - i.e on your laptop.
And folks doing optimized runs should use a properly tuned MPI for their setup anyway.
In this case --download-mpich-device=ch3:nemesis is likely appropriate if using --download-mpich [and not using a separate/optimized MPI]
Having defaults that satisfy all use cases is not practical.
Satish
On Wed, 22 Jul 2020, Matthew Knepley wrote:
We default to ch3:sock. Scott MacLachlan just had a long thread on the Firedrake list where it ended up that reconfiguring using ch3:nemesis had a 2x performance boost on his 16-core proc, and noticeable effect on the 4 core speedup.
Why do we default to sock?
Matt
participants (1)
Junchao Zhang
