Re: [petsc-dev] PETSc blame digest (next) 2018-04-23
Dang, I fixed this yesterday but then forgot to merge the branch barry/bugfix-petscformatconvert into next for testing. Barry
On Apr 23, 2018, at 7:28 AM, PETSc checkBuilds <[email protected]> wrote:
Dear PETSc developer,
This email contains listings of contributions attributed to you by `git blame` that caused compiler errors or warnings in PETSc automated testing. Follow the links to see the full log files. Please attempt to fix the issues promptly or let us know at [email protected] if you are unable to resolve the issues.
Thanks, The PETSc development team
warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/14416c0 Insure PetscPrintf(), PetscVPrintfDefault(), PetscSynchronizedPrintf(), PetscSynchronizedFPrintf(), and PetscViewerASCIIPrintf() handle printed strings longer than the default buffer size of 8*1024 bytes properly
src/sys/classes/viewer/impls/ascii/filev.c:991 [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2018/04/23/build_next_a...] /usr/home/balay/petsc.next/src/sys/classes/viewer/impls/ascii/filev.c:991:20: warning: comparison between signed and unsigned integer expressions [-Wsign-compare] [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2018/04/23/build_next_a...] /home/sandbox/petsc/petsc.next-3/src/sys/classes/viewer/impls/ascii/filev.c:991:43: warning: comparison between signed and unsigned integer expressions [-Wsign-compare] [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2018/04/23/build_next_a...] /sandbox/petsc/petsc.next-2/src/sys/classes/viewer/impls/ascii/filev.c:991:43: warning: comparison between signed and unsigned integer expressions [-Wsign-compare] [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2018/04/23/build_next_a...] /sandbox/petsc/petsc.next/src/sys/classes/viewer/impls/ascii/filev.c:991:43: warning: comparison between signed and unsigned integer expressions [-Wsign-compare] [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2018/04/23/build_next_a...] /sandbox/petsc/petsc.next-3/src/sys/classes/viewer/impls/ascii/filev.c:991:43: warning: comparison between signed and unsigned integer expressions [-Wsign-compare] [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2018/04/23/build_next_a...] /usr/home/balay/petsc.next-2/src/sys/classes/viewer/impls/ascii/filev.c:991:20: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
src/sys/fileio/mprint.c:785 [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2018/04/23/build_next_a...] /sandbox/petsc/petsc.next/src/sys/fileio/mprint.c:785:17: error: 'len' undeclared (first use in this function) [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2018/04/23/build_next_a...] /sandbox/petsc/petsc.next/src/sys/fileio/mprint.c:785:12: warning: unused variable 'buff' [-Wunused-variable]
warnings attributed to commit https://bitbucket.org/petsc/petsc/commits/df41390 fixed problem with Matlab being nonresponsive when run with -nodisplay and built with MPI
src/sys/fileio/mprint.c:788 [http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/archive/2018/04/23/build_next_a...] /sandbox/petsc/petsc.next/src/sys/fileio/mprint.c:788:20: error: 'buf' undeclared (first use in this function)
---- To opt-out from receiving these messages - send a request to [email protected].
participants (1)
Smith, Barry F.
