Re: [petsc-dev] FieldSplit fixes in 3.3
The main reason for this being a patch in 3.3 is that recursive FieldSplit is broken there (which is why I couldn't enable it in libMesh/Moose correctly). More comments below. On Sun, Aug 19, 2012 at 9:32 AM, Jed Brown <[email protected]> wrote:
On Sun, Aug 19, 2012 at 2:31 AM, Dmitry Karpeev <[email protected]>wrote:
I just pushed a couple of fixes to PCFIELDSPLIT in petsc-3.3 ( http://petsc.cs.iit.edu/petsc/releases/petsc-3.3/rev/943dde820f7f,
Yikes:
--- a/src/ksp/pc/impls/fieldsplit/fieldsplit.c +++ b/src/ksp/pc/impls/fieldsplit/fieldsplit.c @@ -14,6 +14,7 @@ PetscInt *fields,*fields_col; VecScatter sctx; IS is,is_col; + DM dm; PC_FieldSplitLink next,previous; };
@@ -263,6 +264,13 @@ if(dms) { ierr = PetscInfo(pc,"Setting up physics based fieldsplit preconditioner using the embedded DM\n");CHKERRQ(ierr); for (ilink=jac->head,i=0; ilink; ilink=ilink->next,i++) { + /* + HACK: + keep a handle to DM here without increfing it: may need the DM to set up the Schur solvers; + can't rely on KSPGetDM() since it will create a DMShell if none was set; + can't use ilink->ksp->dm without creating a dependence on dmimpl.h. + */ + ilink->dm = dms[i];
I think your comment was intended to say "kspimpl.h", but you are creating a tangled web of barbed wire here. You are supposed to call KSPGetDM() and switch based on its *capability*, not *presence*. PETSc should never do something different based on existence of a DM.
I need to pass the DM from the A00 split to the Schur solvers, but not if it's null. If it was PETSC_NULL in the A00 split, KSPGetDM() will give me a DMShell, which will generate an error down the line. I can't reliably get the DM from the split's KSP, so I have to stash it somewhere. Otherwise recursive splits don't work. If there is a better solution, I'm all for it.
- /* set tabbing and options prefix of KSP inside the MatSchur */ + /* set tabbing, options prefix and DM of KSP inside the MatSchur */ ierr = MatSchurComplementGetKSP(jac->schur,&ksp);CHKERRQ(ierr); ierr = PetscObjectIncrementTabLevel((PetscObject)ksp,(PetscObject)pc,2);CHKERRQ(ierr); + { + PC pcinner; + ierr = KSPGetPC(ksp, &pcinner); CHKERRQ(ierr); + ierr = PetscObjectIncrementTabLevel((PetscObject)pcinner,(PetscObject)pc,2);CHKERRQ(ierr); + }
There is KSPIncrementTabLevel() for a reason.
In petsc-dev, but not in petsc-3.3.
- ierr = PetscSNPrintf(schurprefix,sizeof schurprefix,"%sfieldsplit_%s_",((PetscObject)pc)->prefix?((PetscObject)pc)->prefix:"",ilink->splitname);CHKERRQ(ierr); - ierr = KSPSetOptionsPrefix(jac->kspschur,schurprefix);CHKERRQ(ierr); /* really want setfromoptions called in PCSetFromOptions_FieldSplit(), but it is not ready yet */ /* need to call this every time, since the jac->kspschur is freshly created, otherwise its options never get set */ - ierr = KSPSetFromOptions(jac->kspschur);CHKERRQ(ierr); + ierr = PetscSNPrintf(schurprefix,sizeof schurprefix,"%sfieldsplit_%s_",((PetscObject)pc)->prefix?((PetscObject)pc)->prefix:"",ilink->splitname);CHKERRQ(ierr); + ierr = KSPSetOptionsPrefix(jac->kspschur,schurprefix);CHKERRQ(ierr); + ierr = KSPSetFromOptions(jac->kspschur); CHKERRQ(ierr); + ierr = KSPSetUp(jac->kspschur); CHKERRQ(ierr);
Why this KSPSetUp()?
I guess this KSPSetUp() can go.
You have changed the formatting here, but not explained why. (Also, can't you follow PETSc coding guidelines regarding placement of CHKERRQ?)
- } else { - /* set up the individual PCs */ - i = 0; - ilink = jac->head; - while (ilink) { - ierr = KSPSetOperators(ilink->ksp,jac->mat[i],jac->pmat[i],flag);CHKERRQ(ierr); - /* really want setfromoptions called in PCSetFromOptions_FieldSplit(), but it is not ready yet */ - if (!jac->suboptionsset) {ierr = KSPSetFromOptions(ilink->ksp);CHKERRQ(ierr);} - ierr = KSPSetUp(ilink->ksp);CHKERRQ(ierr); - i++; - ilink = ilink->next; - } + } + /* set up the individual PCs */ + i = 0; + ilink = jac->head; + while (ilink) { + ierr = KSPSetOperators(ilink->ksp,jac->mat[i],jac->pmat[i],flag); CHKERRQ(ierr); + /* really want setfromoptions called in PCSetFromOptions_FieldSplit(), but it is not ready yet */ + if (!jac->suboptionsset) {ierr = KSPSetFromOptions(ilink->ksp); CHKERRQ(ierr);} + ierr = KSPSetUp(ilink->ksp);CHKERRQ(ierr); + i++; + ilink = ilink->next;
Why do you want this stuff done even for Schur? At least one of these blocks is not used at all, so why are we setting it up?
In the previous version NONE of these were done for Schur. I suppose we can handle these cases more carefully.
http://petsc.cs.iit.edu/petsc/releases/petsc-3.3/rev/5a9ebf885615)
/* HACK: Check for the constant null space */ - ierr = MatGetNullSpace(pc->pmat, &sp);CHKERRQ(ierr); + /* + This replaces a previous test that checked whether the split's constants are injected into the ambient problem's nullspace. + That can create false negatives (declaring constants not in the nullspace, when they are) as in Stokes or A = [1, 1; 1, 0]. + */ if (sp) {
So now you have stale comments and conditionals based on uninitialized memory (sp)? I suppose your intent is to always do this constant null space check regardless of whether the larger matrix has a null space set. I agree that the old code was incorrect because the restriction of the null space of the parent matrix is not comparable to the null space of the submatrix.
ierr = MatGetNullSpace(jac->pmat[1], &sp);CHKERRQ(ierr); - if (sp) {ierr = MatSetNullSpace(jac->schur, sp);CHKERRQ(ierr);} - /* set tabbing, options prefix and DM of KSP inside the MatSchur */ + /* + Do we really want to attach the A11-block's nullspace to S? Note that this may generate + "false positives", when the A11's nullspace isn't S's: Stokes or A = [1, 1; 1, 0]. + Using a false nullspace may prevent KSP(S) from converging, since it might force an inconsistent rhs. + */ + /* if (sp) {ierr = MatSetNullSpace(jac->schur, sp);CHKERRQ(ierr);} */ + /* set tabbing, options prefix and DM of KSP inside the MatSchurComplement */
I agree with this change, though the comment is incorrect. The typical problem is that S is nonsingular or has a small null space while A11 is has huge null space (e.g. the zero matrix). The true null space projection for the zero matrix prevents progress in any direction.
I think we can repair the second patch, though we really need a general mechanism for providing Schur complement null spaces. Matt advocates attaching it to A11 (where the user knows full well that it's not the null space of A11 when they set it), making the old code "correct".
Okay, I'll back out that part of the second patch, since A11's nullspace is assumed to be meant for S. I'm not sure what's incorrect about the comment, though: if a vector is in the A11's kernel, but not in S's, I call it a "false positive". This terminology may be wanting, but what's incorrect about it?
I think that's confusing and we need a specific API for it, but if people are using it that way, we shouldn't change it in 3.3.
I'd prefer to backout the first patch, split it into separate pieces, and review each before pushing. I think it's a potentially big behavior change for 3.3.
Which pieces of the first patch do you think are too big for 3.3? The splits' and Schur KSPs have to be set up (maybe not all in every situation) in order for recursive splitting to work. Should we declare that capability unavailable for 3.3? I can eliminate the unneeded KSPSetUp() calls. Dmitry.
participants (1)
Dmitry Karpeev
