Re: [petsc-dev] I do not think this is the right solution
On Sun, Mar 18, 2012 at 6:52 PM, Jed Brown <[email protected]> wrote:
On Sun, Mar 18, 2012 at 18:45, Matthew Knepley <[email protected]> wrote:
No, I don't want the nonzeros removed, I want the values set to zero, exactly like I said. This is for robustly checking that a matrix created in parallel is the same as one made on a different number of processors. Something I do for ex62, but we obviously do not give a shit about doing.
What? Why not do a MatGetRedundantMatrix() on the parallel thing and compute a norm of the difference to the serial thing?
That has nothing to do with anything we are talking about.
And if you really want to stay parallel and print all the non-small values, MatDuplicate and fill up the new matrix with the thresholded values.
Neither does this.
Note, there was a request a while back to be able to make an ASCII viewer use a user-defined floating-point format string.
That would not help. For a small number, you do not want ANY significant digits. Matt -- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener
participants (1)
Matthew Knepley
