Re: [petsc-dev] every test example runs in a new directory with new test harness
On Thu, Feb 9, 2017 at 5:54 PM, Barry Smith <[email protected]> wrote:
I had no idea what a subtest was (horrible name BTW) so I said all subtests should have the same output.
I now understand what Scott meant by a subtest but I am still not sure that it is a good idea. The benefits/features of subtests are
1) you don't need to type the base command line arguments multiple times
2) subtests need to be run sequentially in the same work directory
3) others?
Now 1) seems like a nice but not crucial feature. 2) seems like a horrible idea. 2) seems to exist only so we can have test cases like this particular one of yours where the first run generates a file and the second run reads in the file. This type of test is useful because it provides some assurance that the "writing" actually wrote a suitable file (instead of possible garbage that does not get tested). Jed proposed an alternative approach for making sure output files are correct that does not require one test case be run after another. Instead the test harness does a diff (for example hdf5diff) on the output file with a "known" file.
I don't see a downside to Jed's proposal.
So I need to check in this checkpoint file in order to test reading it in, and also the diffing? I am not sure I like that better. Shouldn't we design our test system to do this simple thing, rather than clutter our repository for all time? Matt
Barry
On Feb 9, 2017, at 4:32 PM, Matthew Knepley <[email protected]> wrote:
On Mon, Feb 6, 2017 at 9:15 AM, Scott Kruger <[email protected]> wrote:
The basic idea of running multiple commands within a single shell script was what I called a subtest (for lack of a better word). So:
This almost works. However, the two tests create separate output, but the text below checks both runs against the same output. I tried using a "subsuffix", but it did not change the output filename.
Matt
test: suffix: restart requires: hdf5 args: -run_type test -refinement_limit 0.0 -bc_type dirichlet -interpolate 1 -petscspace_order 1 test: args: -dm_view hdf5:sol.h5 -vec_view hdf5:sol.h5::append test: args: -f sol.h5 -restart
The args in the subtest inherit from the parent test. This seems to be generally useful as a testing idiom in petsc tests as this example nicely shows.
Each mpiexec would be tested separately and reported separately. This would give you want you want, and should work as is.
Tobin pointed out that I broke the for loops and some of the subtest functionality in some of the other feature implementations. We have come to consensus (right, Tobin?) on the desired functionality and implementation. A pull request is planned this week. It doesn't affect this directly, but should have some minor improvements (like in the reporting).
Scott
On 2/6/17 7:10 AM, Matthew Knepley wrote: On Mon, Feb 6, 2017 at 1:05 AM, Jed Brown <[email protected] <mailto:[email protected]>> wrote:
Barry Smith <[email protected] <mailto:[email protected]>> writes:
> test: > suffix: restart_0 > requires: hdf5 > args: -run_type test -refinement_limit 0.0 -bc_type dirichlet -interpolate 1 -petscspace_order 1 -dm_view hdf5:sol.h5 -vec_view hdf5:sol.h5::append > > test: > suffix: restart_1 > requires: hdf5 > args: -run_type test -refinement_limit 0.0 -bc_type dirichlet -interpolate 1 -petscspace_order 1 -f sol.h5 -restart > > See a problem? > > Should the same run of the example view the files and then load them back in? versus trying to read in a data file from another run that may not even have been created before and even if it was, the file was definitely created in a different directory?
So if write only is broken, do you want both to fail? I think it's better to read and write separately, with comparison using h5diff, since that independently tests read vs write and establishes backward compatibility, which you'd really like the test system to make you deal with explicitly.
I know the test is broken, but I did already mail the list about this and was waiting for an answer to be worked out.
I agree with Satish that running two commands would be great. I could rewrite the example to both write and load it, but it would complicate it. Also, I am trying to get the pattern I expect the user to follow for checkpointing.
Matt
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener
-- Tech-X Corporation [email protected] 5621 Arapahoe Ave, Suite A Phone: (720) 974-1841 Boulder, CO 80303 Fax: (303) 448-7756
participants (1)
Matthew Knepley
