Re: [petsc-dev] [petsc-users] make test failed
On Jun 19, 2012, at 1:27 PM, Satish Balay wrote:
Ok - I think the sources were extracted with a windows tool - and not cygwin 'tar' - so the scripts [which got extracted in dos format] are misbehaving.
Satish, Ok, how do we prevent this from ever happening again? When ./configure is run it should first check if the scripts are corrupted from a Windows tool and stop with a nice error message telling the user to use cygwin tar to process the tar file. Please figure out how to make this a patch for 3.3 Thanks Barry
sbalay@ps3 ~/petsc33/src/ksp/ksp/examples/tutorials $ unix2dos.exe /home/sbalay/petsc33/bin/mpiexec.uni unix2dos: converting file /home/sbalay/petsc33/bin/mpiexec.uni to DOS format ...
sbalay@ps3 ~/petsc33/src/ksp/ksp/examples/tutorials $ /home/sbalay/petsc33/bin/mpiexec.uni -n 1 ./ex2 /home/sbalay/petsc33/bin/mpiexec.uni: line 4: syntax error near unexpected token `elif' 'home/sbalay/petsc33/bin/mpiexec.uni: line 4: `elif [ $2 = "1" ]; then
sbalay@ps3 ~/petsc33/src/ksp/ksp/examples/tutorials $ dos2unix.exe /home/sbalay/petsc33/bin/mpiexec.uni dos2unix: converting file /home/sbalay/petsc33/bin/mpiexec.uni to Unix format ...
sbalay@ps3 ~/petsc33/src/ksp/ksp/examples/tutorials $ /home/sbalay/petsc33/bin/mpiexec.uni -n 1 ./ex2 Norm of error 0.000156044 iterations 6
Satish
On Tue, 19 Jun 2012, Barry Smith wrote:
Please run
/bin/sh --version
and send the output
On Jun 18, 2012, at 5:21 PM, Yifei Li wrote:
Hi all,
I got the following error when running 'make test':
Using PETSC_DIR=/home/liyi0000/petsc-3.3-p1 and PETSC_ARCH=arch-mswin-c-debug Possible error running C/C++ src/snes/examples/tutorials/ex19 with 1 MPI process
See http://www.mcs.anl.gov/petsc/documentation/faq.html /home/liyi0000/petsc-3.3-p1/bin/mpiexec.uni: line 4: syntax error near unexpected token 'elif' 'home/liyi0000/petsc-3.3-p1/bin/mpiexec.uni: line 4: 'elif [ $2 = "1" ]; then
Can someone help me with this? Thanks
Yifei
participants (1)
Barry Smith
