Re: [petsc-dev] obscure changes in TSGetStages_Theta
Done. Please check https://gitlab.com/petsc/petsc/-/merge_requests/3583 Sorry for any disturbance it caused. It was for the convenience of the adjoint implementation. The stages returned by TSGetStages_Theta currently do not reflect the true stages associated with these methods. The endpoint variant actually has two stages. This will be changed in a separate forthcoming MR, where TSRestoreStages() will be added and TSGetStages will return an array of vectors for the endpoint variant. Hong On Jan 21, 2021, at 4:16 AM, Stefano Zampini <[email protected]<mailto:[email protected]>> wrote: Hong, I do not understand why you changed the behavior of TSGetStages_Theta https://gitlab.com/petsc/petsc/-/merge_requests/3500/diffs#a582bbaec75f4ae14... with this MR https://gitlab.com/petsc/petsc/-/merge_requests/3500 Now, the non-endpoint variant does no longer use th->X as stage! Please revert this change Thanks -- Stefano
participants (1)
Zhang, Hong
