Re: [petsc-dev] p4est configure error
perhaps configure was not rerun - so a stale p4est was being used.. Satish On Thu, 7 Jul 2016, Tobin Isaac wrote:
p4est.py automatically pulls from whatever p4est branch I call 'petsc' in my repo, so I don't see how this problem persists if you really nuked it.
- Did you nuke the right directory? - Did you send me the right configure.log? - Is the new failure the same (the same stale p4est commit is being used)?
On Thu, Jul 07, 2016 at 08:33:57PM +0200, Mark Adams wrote:
It sounds like I have not merged your fix. Should I pull from master?
I have nuked this many times.
On Thu, Jul 7, 2016 at 4:26 PM, Tobin Isaac <[email protected]> wrote:
On Thu, Jul 07, 2016 at 03:16:40PM +0200, Mark Adams wrote:
p4est on Edison configures in w/o debugging, although I have to run configure twice. But with debugging it fails. I can not see any difference between the two configures other than debugging. Mark
The log shows that you are configuring a p4est commit (3d3e1) that is before the one I pushed specifically to avoid the fortran configuration error (f54bb3). Please clear the git.p4est directory, and confirm that you are configuring with the current 'petsc' branch of p4est (`grep 'checking Point version' configure.log` should show X.XXX-a9f22).
Cheers, Toby
participants (1)
Satish Balay
