Re: [petsc-dev] broken options handling with intel 16.0 compilers on mac OS
On Sep 22, 2015, at 11:16 PM, Satish Balay <[email protected]> wrote:
On Tue, 22 Sep 2015, Blaise A Bourdin wrote:
With the later configuration, it looks like what matters is the order in which -lmpifort and -lifcore are listed: This one works: mpif90 -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -g -O0 -I/opt/HPC/petsc-dev/include/petsc/finclude -o ex5f90 ex5f90.o -Wl,-rpath,/opt/HPC/petsc-dev/Darwin-intel16.0-g/lib -L/opt/HPC/petsc-dev/Darwin-intel16.0-g/lib -lpetsc -Wl,-rpath,/opt/intel-16.0/compilers_and_libraries_2016.0.083/mac/compiler/lib -L/opt/intel-16.0/compilers_and_libraries_2016.0.083/mac/compiler/lib -Wl,-rpath,/opt/intel-16.0/compilers_and_libraries_2016.0.083/mac/mkl/lib -lifcore -lmpifort
This one does not: mpif90 -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -g -O0 -I/opt/HPC/petsc-dev/include/petsc/finclude -o ex5f90 ex5f90.o -Wl,-rpath,/opt/HPC/petsc-dev/Darwin-intel16.0-g/lib -L/opt/HPC/petsc-dev/Darwin-intel16.0-g/lib -lpetsc -Wl,-rpath,/opt/intel-16.0/compilers_and_libraries_2016.0.083/mac/compiler/lib -L/opt/intel-16.0/compilers_and_libraries_2016.0.083/mac/compiler/lib -Wl,-rpath,/opt/intel-16.0/compilers_and_libraries_2016.0.083/mac/mkl/lib -lmpifort -lifcore
Does linking with -lifcore vs /opt/intel-16.0/compilers_and_libraries_2016.0.083/mac/compiler/lib/libifcore.a make a difference? It does. When I specify the path explicitly, the build works, regardless of the order in which libmpifort and libifcore are listed.
And what do you have for:
cd /opt/HPC/mpich-3.1.4-intel16.0/lib ls nm -Ao libmpiifort.* |grep get_command_argument This gives nothing at all: bourdin@galerkin:lib $ nm -Ao lib* |grep -i command bourdin@galerkin:lib $
BTW: I'm assuming you have sept 20 or newer petsc master branch.
Yes. I have checked out your changes before testing. Out of curiosity: it looks like linking with -lpetsc is enough, so why use this very complicated link command? i.e. this is enough to produce a perfectly fine binary: mpif90 -Wl,-multiply_defined,suppress -Wl,-multiply_defined -Wl,suppress -Wl,-commons,use_dylibs -Wl,-search_paths_first -g -O0 -I/opt/HPC/petsc-dev/include/petsc/finclude -o ex5f90 ex5f90.o -Wl,-rpath,/opt/HPC/petsc-dev/Darwin-intel16.0-g/lib -L/opt/HPC/petsc-dev/Darwin-intel16.0-g/lib -lpetsc Blaise -- Department of Mathematics and Center for Computation & Technology Louisiana State University, Baton Rouge, LA 70803, USA Tel. +1 (225) 578 1612, Fax +1 (225) 578 4276 http://www.math.lsu.edu/~bourdin
participants (1)
Blaise A Bourdin
