Re: [petsc-dev] get rid of petscsys.hh?
How about just embedding the information directly into the petscsys.h file and putting a comment explaining its purpose
On Jan 2, 2014, at 10:10 AM, Matthew Knepley <[email protected]> wrote:
On Wed, Jan 1, 2014 at 2:10 PM, Barry Smith <[email protected]> wrote:
Matt,
You removed petscsys.hh but also need to remove its dependencies
I don't think we can remove this. I fixed the include.
Matt
CXX arch-pylith-gcc-opt/obj/src/sys/error/err.o /Users/buildbot/slave/build/pylith_darwin_10.6_binbot/PETSc/petsc-pylith/binaries/src/sys/error/err.c: In function 'void PetscCxxErrorThrow()': /Users/buildbot/slave/build/pylith_darwin_10.6_binbot/PETSc/petsc-pylith/binaries/src/sys/error/err.c:304:5: error: 'ostringstream' is not a member of 'std' /Users/buildbot/slave/build/pylith_darwin_10.6_binbot/PETSc /petsc-pylith/binaries/src/sys/error/err.c:304:25: error: 'msg' was not declared in this scope /Users/buildbot/slave/build/pylith_darwin_10.6_binbot/PETSc/petsc-pylith/binaries/src/sys/error/err.c:305:12: error: 'ostringstream' is not a member of 'std'
/Users/buildbot/slave/build/pylith_darwin_10.6_binbot/PETSc/petsc-pylith/binaries/src/sys/error/err.c:305:31: error: expected primary-expression before ')' token /Users/buildbot/slave/build/pylith_darwin_10.6_binbot/PETSc/petsc-pylith/binaries/src/sys/error/err.c:305:33: error: expected ';' before 'eh' /Users/buildbot/slave/build/pylith_darwin_10.6_binbot/PETSc/petsc-pylith/binaries/src/sys/error/err.c:309:9: error: 'PETSc' has not been declared make[2]: *** [arch-pylith-gcc-opt/obj/src/sys/error/err.o] Error 1
On Dec 26, 2013, at 2:59 PM, Matthew Knepley <[email protected]> wrote:
On Thu, Dec 26, 2013 at 2:41 PM, Barry Smith <[email protected]> wrote:
Can we get rid of petscsys.hh which still? seems to be lurking in master?
I will get rid of it.
Matt
Thanks
Barry
/* Special support for C++ */ #if defined(PETSC_CLANGUAGE_CXX) && defined(__cplusplus) #include <petscsys.hh> #endif
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener
participants (1)
Barry Smith
