Re: [petsc-dev] "Search" does not work in the testing system?
You can change the 'test' target to 'print-test' to see the actual targets you'll be testing. You can also just change your search string to src/snes/tutorials/ex1.c to grab all tests associated with ex1.c. Scott On 1/27/21 4:45 PM, Zhang, Hong via petsc-dev wrote:
make PETSC_DIR=/Users/kongf/projects/moose4/petsc PETSC_ARCH=arch-darwin-c-debug -f gmakefile test search='snes_tutorials-ex1_*'
or
make PETSC_DIR=/Users/kongf/projects/moose4/petsc PETSC_ARCH=arch-darwin-c-debug -f gmakefile test globsearch='snes_tutorials-ex1_*’
Hong (Mr.)
On Jan 27, 2021, at 5:21 PM, Fande Kong <[email protected]> wrote:
Hi All,
I want to run one particular SNES test using the following command-line:
"make PETSC_DIR=/Users/kongf/projects/moose4/petsc PETSC_ARCH=arch-darwin-c-debug -f gmakefile test search='snes_tutorials-ex1'"
I got the following output:
"Using MAKEFLAGS: search=snes_tutorials-ex1% PETSC_ARCH=arch-darwin-c-debug PETSC_DIR=/Users/kongf/projects/moose4/petsc"
But I did not see any useful test information.
Could you kindly let me know what I did wrong?
Fande
-- Tech-X Corporation [email protected] 5621 Arapahoe Ave, Suite A Phone: (720) 466-3196 Boulder, CO 80303 Fax: (303) 448-7756
participants (1)
Scott Kruger
