Re: [petsc-dev] metis config error on XT4
30 Nov
30 Nov
'11
4:49 p.m.
On Nov 30, 2011, at 4:44 PM, Jed Brown wrote:
On Wed, Nov 30, 2011 at 16:40, Jack Poulson <[email protected]> wrote: No, but perhaps I should. My understanding is that those lines only need to be changed when ParMetis is included as a subproject, as they seem to have configured the build system to use relative paths.
That's a misuse of CMake. Normally you build from a separate build directory (so that you can clean reliably and independently between configurations). That ParMetis misuses CMake by default isn't an excuse for not allowing it to be used properly.
A well designed buildsystem would not allow itself to be misused.
5366
Age (days ago)
5366
Last active (days ago)
0 comments
1 participants
participants (1)
Barry Smith
