Kokkos-Serial is working on Landau ex2, but I get this error with OMP. gmake[2]: *** [src/CMakeFiles/kokkoskernels.dir/build.make:1040: src/CMakeFiles/kokkoskernels.dir/impl/generated_specializations_cpp/spmv/Sparse_spmv_mv_struct_eti_DOUBLE_ORDINAL_INT_OFFSET_INT_LAYOUTLEFT_EXECSPACE_SERIAL_MEMSPACE_HOSTSPACE.cpp.o] Error 9 Good old Error 9. The Kokkos people (Trott) have a Fujitsu box that they seem willing to dive in. I will run this by them. On Thu, Apr 15, 2021 at 3:11 PM Satish Balay <[email protected]> wrote:
BTW:
login6$ mpifccpx -fopenmp -v sizeof.c fccpx: Fujitsu C/C++ Compiler 4.5.0 tcsds-1.2.31 simulating gcc version 6.1 /opt/FJSVxtclanga/tcsds-1.2.31/bin/../lib/ccpcompx --preinclude /opt/FJSVxtclanga/tcsds-1.2.31/bin/../lib/fcc.pre --gcc -Dunix -Dlinux -D__FUJITSU -D__FCC_major__=4 -D__FCC_minor__=5 -D__FCC_patchlevel__=0 -D__FCC_version__="4.5.0" -D__aarch64__ -D__unix -D_OPENMP=201107 -D__fcc_version__=0x800 -D__fcc_version=800 -D__USER_LABEL_PREFIX__= -D__ARM_ARCH=8 -D__ARM_FEATURE_SVE -D__FP_FAST_FMA -D__ELF__ -D__unix__ -D__linux__ -D__linux -Asystem(unix) -D__LIBC_6B -D__LP64__ -D_LP64 --K=omp -I/opt/FJSVxtclanga/.common/MELI024/include/mpi/fujitsu -D_REENTRANT --K=noocl -D_REENTRANT -D__MT__ --zmode=64 --sys_include=/opt/FJSVxtclanga/tcsds-1.2.31/bin/../include --sys_include=/opt/FJSVxos/devkit/aarch64/rfs/usr/include sizeof.c -- -ncmdname=fccpx -zcfc=target_sve -Kopenmp -V -Kthreadsafe -Klargepage -otmp /home/ra010009/a04201/asmHUx9OT.s ccpcompx: Fujitsu C/C++ Compiler 4.5.0 (Mar 4 2021 13:29:06) /opt/FJSVxtclanga/tcsds-1.2.31/bin/../bin/checklogpx -v -zlangC MPI:V4.5.0 -fopenmp -v /home/ra010009/a04201/asmHUx9OT.s /opt/FJSVxos/devkit/aarch64/bin/aarch64-linux-gnu-as -o /home/ra010009/a04201/fccmPXe0C.o -march=armv8.3-a+sve -v /home/ra010009/a04201/asmHUx9OT.s GNU assembler version 2.30 (aarch64-linux-gnu) using BFD version version 2.30-49.el8 /opt/FJSVxos/devkit/aarch64/bin/aarch64-linux-gnu-ld --build-id --sysroot=/opt/FJSVxos/devkit/aarch64/rfs --eh-frame-hdr -m aarch64linux -dynamic-linker /lib/ld-linux-aarch64.so.1 /opt/FJSVxos/devkit/aarch64/rfs/usr/lib64/crt1.o /opt/FJSVxos/devkit/aarch64/rfs/usr/lib64/crti.o /opt/FJSVxos/devkit/aarch64/lib/gcc/aarch64-linux-gnu/8/crtbegin.o -lfjprofmpi -L/opt/FJSVxos/devkit/aarch64/lib/gcc/aarch64-linux-gnu/8 -v /home/ra010009/a04201/fccmPXe0C.o -L/opt/FJSVxtclanga/.common/MELI024/lib64 -lmpi -lfjstring_internal -L/opt/FJSVxos/devkit/aarch64/lib/gcc/aarch64-linux-gnu/8/../../../../aarch64-linux-gnu/lib/../lib64 /opt/FJSVxtclanga/tcsds-1.2.31/bin/../lib64/fjcrt0.o /opt/FJSVxtclanga/tcsds-1.2.31/bin/../lib64/fjlang08.o /opt/FJSVxtclanga/tcsds-1.2.31/bin/../lib64/fjomp.o /opt/FJSVxtclanga/tcsds-1.2.31/bin/../lib64/fjhpctag.o -L/opt/FJSVxtclanga/tcsds-1.2.31/bin/../lib64 -lfjomphk -lfjomp -lfj90i -lfj90fmt_sve -lfj90f -lfjsrcinfo -lfjcrt -lfjompcrt -lfjprofcore -lfjprofomp -lmpg -lm -l atomic -lpthread -L/opt/FJSVxos/devkit/aarch64/rfs/usr/lib64 -L/opt/FJSVxos/devkit/aarch64/rfs/opt/FJSVxos/mmm/lib64 -L/opt/FJSVxtclanga/tcsds-1.2.31/bin/../lib64/nofjobj -T/opt/FJSVxos/devkit/aarch64/rfs/opt/FJSVxos/mmm/util/bss-2mb.lds -lm -lrt -lpthread -lelf -lz -ldl -lgcc_s -lgcc -lc -lgcc_s -lgcc -lc /opt/FJSVxos/devkit/aarch64/lib/gcc/aarch64-linux-gnu/8/crtend.o /opt/FJSVxos/devkit/aarch64/rfs/usr/lib64/crtn.o GNU ld version 2.30-49.el8 <<<<
i.e -fopenmp is internally mapped to -Kopenmp
Satish
On Wed, 14 Apr 2021, Mark Adams wrote:
The compiler:
FCC (FCC) 4.5.0 20210304
*simulating gcc version 6.1*Copyright FUJITSU LIMITED 2019-2021
and -Kopenmp specifies to enable the Specification of OpenMP Application Program Interface. The -Knoopenmp option invalidates the -Kopenmp option. -Knoopenmp is set by default.
When the -Kopenmp option is specified, -mt is assumed.
*The -Kopenmp option is needed if an object program compiled with it exists in the command line as an input file.*
I am going to try w/o Kopenmp.
On Wed, Apr 14, 2021 at 8:15 PM Satish Balay <[email protected]> wrote:
I don't understand kokkos build errors.
For one - kokkos-kernels are taking long to build. And on the back end
I'm getting into time limit [and terminated]
Kokkos take a very long time in configure on Summit.
Trying a build on the front-end - its running - for a long time..
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND 4016901 a04201 20 0 11.0g 10.7g 13876 R 99.3 11.6 66:22.35 ccpcompx
The above compile process has been running for more than an hour. Ok -
its
finally done.
When I enable openmp - kokkos cmake completes - but I get errors at build time [BTW: I don't understand difference between -fopenmp and -Kopenmp]
login6$
../petsc.save/arch-linux2-c-opt/lib/petsc/conf/reconfigure-arch-linux2-c-opt.py
--with-p4est-dir=$HOME/p4est-install --with-zlib-dir=$HOME/p4est-install -download-kokkos --download-kokkos-kernelsx --download-kokkos-commit=origin/develop --download-kokkos-kernels-commit=origin/develop --download-cmake=
https://github.com/Kitware/CMake/releases/download/v3.20.1/cmake-3.20.1.tar....
'--download-kokkos-cmake-arguments=-DBUILD_TESTING=OFF -DKokkos_ENABLE_LIBDL=OFF -DKokkos_ENABLE_AGGRESSIVE_VECTORIZATION=ON -DKokkos_ENABLE_OPENMP=ON' --ignoreLinkOutput=1 --with-openmp=1
/a04201/petsc.x/arch-linux2-c-opt/externalpackages/git.kokkos/petsc-build/core/src
-I/vol0004/ra010009/a04201/petsc.x/arch-linux2-c-opt/externalpackages/git.kokkos/core/src
-I/vol0004/ra010009/a04201/petsc.x/arch-linux2-c-opt/externalpackages/git.kokkos/petsc-build
-O -fopenmp -fPIC -fopenmp -O -fopenmp -fPIC -fopenmp -fopenmp -std=c++14 -o CMakeFiles/kokkoscore.dir/OpenMP/Kokkos_OpenMP_Task.cpp.o -c
/vol0004/ra010009/a04201/petsc.x/arch-linux2-c-opt/externalpackages/git.kokkos/core/src/OpenMP/Kokkos_OpenMP_Task.cpp
gmake[2]: Leaving directory
'/vol0004/ra010009/a04201/petsc.x/arch-linux2-c-opt/externalpackages/git.kokkos/petsc-build'
gmake[1]: Leaving directory
'/vol0004/ra010009/a04201/petsc.x/arch-linux2-c-opt/externalpackages/git.kokkos/petsc-build'/home/ra010009/a04201/asmqkagl0.s:
Assembler messages: /home/ra010009/a04201/asmqkagl0.s:20333: Error: symbol `.LEHB41' is already defined /home/ra010009/a04201/asmqkagl0.s:21334: Error: symbol `.LEHB41' is already defined gmake[2]: *** [core/src/CMakeFiles/kokkoscore.dir/build.make:312: core/src/CMakeFiles/kokkoscore.dir/OpenMP/Kokkos_OpenMP_Exec.cpp.o] Error 1
Note: I have a successful configure run with p4est+kokkos+kokkos-kernels, without-openmp [for this - I had to build p4est on the back-end, then switch over to front-end - and build the reset of the packages]
Now I'm stuck at compiling petsc sources - src/vec/is/sf/impls/basic/kokkos/sfkok.kokkos.cxx
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND 56491 a04201 20 0 4944176 4.5g 11216 R 98.4 4.9 12:45.52 ccpcompx
Satish
PETSc seems to be skipping the compiler that it should use:
-- Check for working CXX compiler: /opt/FJSVxtclanga/tcsds-1.2.31/bin/mpiFCC - skipped
I see -fopenmp was added. This might be wrong. I use -Kopenmp.
--help says:
-fopenmp
The -fopenmp option specifies to enable Specification of OpenMP Appli- cation Program Interface.
When the -fopenmp option is specified, -mt is set.
The -fopenmp option is needed if an object program compiled with the -fopenmp option exists in the command line as input files.
Any ideas?
On Wed, Apr 14, 2021 at 5:17 PM Satish Balay <[email protected]> wrote:
The following is working for me on the compute node [its completed kokkos (core) build - and is now building kokkos-kernels
~/petsc.save/arch-arm/lib/petsc/conf/reconfigure-arch-arm.py --download-p4est --download-zlib --download-kokkos --download-kokkos-kernels --download-kokkos-commit=origin/develop --download-cmake=
-DKokkos_ENABLE_OPENMP=ON give me some issue - so I didn't try any
of the
additional options..
Satish
Satish, I get this error.
I wonder if this syntax is wrong:
'--download-kokkos-cmake-arguments=-DCMAKE_BUILD_TYPE=Release -DBUILD_TESTING=OFF -DKokkos_ENABLE_LIBDL=OFF -DKokkos_ENABLE_OPENMP=ON -DKokkos_ENABLE_SERIAL=ON -DKokkos_ENABLE_AGGRESSIVE_VECTORIZATION=ON',
Configuring KOKKOS with cmake;
this may take
several minutes
Executing: /usr/bin/cmake .. -DCMAKE_INSTALL_PREFIX=/home/ra010009/a04199/petsc/arch-arm
-DCMAKE_INSTALL_NAME_DIR:STRING="/home/ra010009/a04199/petsc/arch-arm/lib"
-DCMAKE_INSTALL_LIBDIR:STRING="lib" -DCMAKE_VERBOSE_MAKEFILE=1 -DCMAKE_BUILD_TYPE=Release -DCMAKE_C_COMPILER="mpifcc" -DMPI_C_COMPILER="mpifcc" -DCMAKE_AR=/usr/bin/ar -DCMAKE_RANLIB=/usr/bin/ranlib -DCMAKE_C_FLAGS:STRING="-fPIC -Kfast,openmp -fopenmp" -DCMAKE_C_FLAGS_DEBUG:STRING="-fPIC -Kfast,openmp -fopenmp" -DCMAKE_C_FLAGS_RELEASE:STRING="-fPIC -Kfast,openmp -fopenmp" -DCMAKE_CXX_COMPILER="mpiFCC" -DMPI_CXX_COMPILER="mpiFCC" -DCMAKE_CXX_FLAGS:STRING="-Kfast,openmp -fopenmp -fPIC -fopenmp" -DCMAKE_CXX_FLAGS_DEBUG:STRING="-Kfast,openmp -fopenmp -fPIC -fopenmp" -DCMAKE_CXX_FLAGS_RELEASE:STRING="-Kfast,openmp -fopenmp -fPIC -fopenmp" -DCMAKE_Fortran_COMPILER="mpifrt" -DMPI_Fortran_COMPILER="mpifrt" -DCMAKE_Fortran_FLAGS:STRING="-fPIC -O -fopenmp" -DCMAKE_Fortran_FLAGS_DEBUG:STRING="-fPIC -O -fopenmp" -DCMAKE_Fortran_FLAGS_RELEASE:STRING="-fPIC -O -fopenmp" -DCMAKE_EXE_LINKER_FLAGS:STRING=" -fopenmp" -DBUILD_SHARED_LIBS:BOOL=ON -DUSE_XSDK_DEFAULTS=YES -DXSDK_ENABLE_DEBUG=NO -DCMAKE_INSTALL_RPATH_USE_LINK_PATH:BOOL=ON -DCMAKE_BUILD_WITH_INSTALL_RPATH:BOOL=ON -DKokkos_ENABLE_MPI=ON -DKokkos_ENABLE_SERIAL=ON -DKokkos_ENABLE_OPENMP=ON -DCMAKE_CXX_STANDARD="14" -DCMAKE_BUILD_TYPE=Release -DBUILD_TESTING=OFF -DKokkos_ENABLE_LIBDL=OFF -DKokkos_ENABLE_OPENMP=ON -DKokkos_ENABLE_SERIAL=ON -DKokkos_ENABLE_AGGRESSIVE_VECTORIZATION=ON stdout: -- Setting default Kokkos CXX standard to 14 -- The CXX compiler identification is Fujitsu -- Check for working CXX compiler: /opt/FJSVxtclanga/tcsds-1.2.31/bin/mpiFCC -- Check for working CXX compiler: /opt/FJSVxtclanga/tcsds-1.2.31/bin/mpiFCC -- works -- Detecting CXX compiler ABI info -- Detecting CXX compiler ABI info - done -- The project name is: Kokkos -- Configuring incomplete, errors occurred! See also
"/vol0004/ra010009/a04199/petsc/arch-arm/externalpackages/git.kokkos/petsc-build/CMakeFiles/CMakeOutput.log".
Error configuring KOKKOS with cmake Could not
execute
"['/usr/bin/cmake .. -DCMAKE_INSTALL_PREFIX=/home/ra010009/a04199/petsc/arch-arm
-DCMAKE_INSTALL_LIBDIR:STRING="lib" -DCMAKE_VERBOSE_MAKEFILE=1 -DCMAKE_BUILD_TYPE=Release -DCMAKE_C_COMPILER="mpifcc" -DMPI_C_COMPILER="mpifcc" -DCMAKE_AR=/usr/bin/ar -DCMAKE_RANLIB=/usr/bin/ranlib -DCMAKE_C_FLAGS:STRING="-fPIC -Kfast,openmp -fopenmp" -DCMAKE_C_FLAGS_DEBUG:STRING="-fPIC -Kfast,openmp -fopenmp" -DCMAKE_C_FLAGS_RELEASE:STRING="-fPIC -Kfast,openmp -fopenmp" -DCMAKE_CXX_COMPILER="mpiFCC" -DMPI_CXX_COMPILER="mpiFCC" -DCMAKE_CXX_FLAGS:STRING="-Kfast,openmp -fopenmp -fPIC -fopenmp" -DCMAKE_CXX_FLAGS_DEBUG:STRING="-Kfast,openmp -fopenmp -fPIC -fopenmp" -DCMAKE_CXX_FLAGS_RELEASE:STRING="-Kfast,openmp -fopenmp -fPIC -fopenmp" -DCMAKE_Fortran_COMPILER="mpifrt" -DMPI_Fortran_COMPILER="mpifrt" -DCMAKE_Fortran_FLAGS:STRING="-fPIC -O -fopenmp" -DCMAKE_Fortran_FLAGS_DEBUG:STRING="-fPIC -O -fopenmp" -DCMAKE_Fortran_FLAGS_RELEASE:STRING="-fPIC -O -fopenmp" -DCMAKE_EXE_LINKER_FLAGS:STRING=" -fopenmp" -DBUILD_SHARED_LIBS:BOOL=ON -DUSE_XSDK_DEFAULTS=YES -DXSDK_ENABLE_DEBUG=NO -DCMAKE_INSTALL_RPATH_USE_LINK_PATH:BOOL=ON -DCMAKE_BUILD_WITH_INSTALL_RPATH:BOOL=ON -DKokkos_ENABLE_MPI=ON -DKokkos_ENABLE_SERIAL=ON -DKokkos_ENABLE_OPENMP=ON -DCMAKE_CXX_STANDARD="14" -DCMAKE_BUILD_TYPE=Release -DBUILD_TESTING=OFF -DKokkos_ENABLE_LIBDL=OFF -DKokkos_ENABLE_OPENMP=ON -DKokkos_ENABLE_SERIAL=ON -DKokkos_ENABLE_AGGRESSIVE_VECTORIZATION=ON']": -- Setting default Kokkos CXX standard to 14 -- The CXX compiler identification is Fujitsu -- Check for working CXX compiler: /opt/FJSVxtclanga/tcsds-1.2.31/bin/mpiFCC -- Check for working CXX compiler: /opt/FJSVxtclanga/tcsds-1.2.31/bin/mpiFCC -- works -- Detecting CXX compiler ABI info -- Detecting CXX compiler ABI info - done -- The project name is: Kokkos -- Configuring incomplete, errors occurred! See also
"/vol0004/ra010009/a04199/petsc/arch-arm/externalpackages/git.kokkos/petsc-build/CMakeFiles/CMakeOutput.log".CMake
Error at cmake/kokkos_compiler_id.cmake:129 (STRING):
* STRING sub-command REPLACE requires at least four arguments.*Call Stack (most recent call first): cmake/kokkos_tribits.cmake:174 (INCLUDE) CMakeLists.txt:166 (KOKKOS_SETUP_BUILD_ENVIRONMENT)
On Wed, Apr 14, 2021 at 3:34 PM Satish Balay <[email protected]> wrote:
Additional kokkos cmake arguments can be passed in via --download-kokkos-cmake-arguments=string option.
Satish
Satish,
For the fujitsu compiler OMP is -Kopenmp.
Sarat (cc'ed) tells me that he built Kokkos with:
cmake -DCMAKE_BUILD_TYPE=Release \ -DCMAKE_INSTALL_PREFIX=${KOKKOS_SRC_DIR}/install \ -DBUILD_TESTING=OFF \ -DKokkos_ENABLE_LIBDL=OFF \ -DKokkos_ENABLE_OPENMP=ON \ -DKokkos_ENABLE_SERIAL=ON \ -DKokkos_ENABLE_AGGRESSIVE_VECTORIZATION=ON \ ..
How might I make this happen in PETSc?
Thanks, Mark
I have this building now. Do you know anything about OpenMP? I can add --with-openmp That should get Kokkos to be made with OpenMP. Should PETSc deal with the compilers correctly?
Well it tries the following compiler options for openmp.
oflags = ["-fopenmp", # Gnu "-qsmp=omp",# IBM XL C/C++ "-h omp", # Cray. Must come after XL because XL interprets this option as meaning "-soname omp" "-mp", # Portland Group "-Qopenmp", # Intel windows "-openmp", # Intel "-xopenmp", # Sun "+Oopenmp", # HP "/openmp" # Microsoft Visual Studio ]
I don't know what the flag for fugaku compiler is.
Satish
Thanks, Mark
On Wed, Apr 14, 2021 at 1:45 PM Mark Adams < [email protected]> wrote:
Thanks, If you feel inspired you could try Kokkos :|| I am in a parking lot waiting for my daughter but can try this when I get home, Thanks again, Mark
On Wed, Apr 14, 2021 at 1:33 PM Satish Balay < [email protected]> wrote:
I think I allocated a single node - and did the build on it.
Now I'm getting an error - don't know what changed..
login6$ pjsub --interact -L "node=1" -L "rscunit=rscunit_ft01" -L "rscgrp=eap-int" -L "elapse=1:00:00" --sparam "wait-time=600" [ERR.] PJM 0059 pjsub rscgrp=eap-int is disabled.
Ok - the following worked..
login6$ pjsub --interact -L "node=1" -L "rscunit=rscunit_ft01" -L "elapse=1:00:00" --sparam "wait-time=600" [INFO] PJM 0000 pjsub Job 6301572 submitted. [INFO] PJM 0081 .connected. [INFO] PJM 0082 pjsub Interactive job 6301572 started. [a04201@j31-3110s petsc]$
Ok - trying this build now.
[a04201@j31-3110s petsc]$ cat
#!/usr/bin/python3 if __name__ == '__main__': import sys import os sys.path.insert(0, os.path.abspath('config')) import configure configure_options = [ '--with-blaslapack-lib=-lfjlapack', '--with-debugging=0', 'CC=mpifcc', 'CXX=mpiFCC', 'FC=mpifrt', 'PETSC_ARCH=arch-arm', ] configure.petsc_configure(configure_options) [a04201@j31-3110s petsc]$
--download-p4est --download-zlib <snip> p4est: Includes: -I/vol0004/ra010009/a04201/petsc/arch-arm/include Library: -Wl,-rpath,/vol0004/ra010009/a04201/petsc/arch-arm/lib -L/vol0004/ra010009/a04201/petsc/arch-arm/lib -lp4est -lsc
Ok - this worked for me.
Satish
Do you recall what nodes you use to build on a "compute" node, to avoid cross compilation?
On Wed, Apr 14, 2021 at 12:08 PM Satish Balay < [email protected]> wrote:
looks like p4est cannot be cross-compiled.
Satish
I get this error with p4est on Fugaku. It is a Fortran error. Odd. Mark
participants (1)
Mark Adams
