Re: [petsc-dev] Problem about DMPlexCreateExodusFromFile()
On Mon, Oct 11, 2021 at 9:29 AM Gong Yujie <[email protected]> wrote:
I'm learning PETSc DMPlex module recently. A problem occurs to my PETSc when I'm using DMPlexCreateExodusFromFile() to import a mesh file. I've tried to generate a mesh with Pointwise and ICEM, but both mesh files can't be input to PETSc. The Error code is :
I am not familiar with Pointwise or ICEM. The problem here is that the element type 'TRIANGLE' is not recognized by PETSc, and it does not appear in the ExodusII documentation that I am using: https://gsjaardema.github.io/seacas-docs/html/element_types.html It is also not used by Cubit/Trellis. I am not sure why your program is making non-standard ExodusII files. Thanks, Matt
*[0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------* *[0]PETSC ERROR: Invalid argument* *[0]PETSC ERROR: Unrecognized element type TRIANGLE* *[0]PETSC ERROR: See https://petsc.org/release/faq/ <https://petsc.org/release/faq/> for trouble shooting.* *[0]PETSC ERROR: Petsc Release Version 3.16.0, Sep 29, 2021* *[0]PETSC ERROR: ./exocircle on a arch-linux-c-debug named DESKTOP-0RMI66F by fstcam Mon Oct 11 10:54:35 2021* *[0]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++ --with-fc=gfortran --download-mpich --download-fblaslapack --download-metis --download-parmetis --download-exodusii --download-netcdf --download-hdf5 --download-superlu --download-triangle --download-zlib --download-pnetcdf --download-make --download-cmake* *[0]PETSC ERROR: #1 ExodusGetCellType_Internal() at /home/fstcam/petsc/petsc-3.16.0/src/dm/impls/plex/plexexodusii.c:1390[0]PETSC ERROR: #2 DMPlexCreateExodus() at /home/fstcam/petsc/petsc-3.16.0/src/dm/impls/plex/plexexodusii.c:1472* *[0]PETSC ERROR: #3 DMPlexCreateExodusFromFile() at /home/fstcam/petsc/petsc-3.16.0/src/dm/impls/plex/plexexodusii.c:1352*
Looking forward to your reply!
Best Regards, Gong
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
participants (1)
Matthew Knepley
